bleed screw spanner size
Posted: December 6th, 2005, 4:30 pm
by AZ-3,1498cc,UK
Tried to open bleed screw on rear caliper to bleed the brakes, 8mm spanner not tight enough on nut will not turn, 7mm way to small! Have i rounded off the nut or do i need a special tool to open the screw?
Posted: December 6th, 2005, 11:45 pm
by PATDIESEL
It is a 7 or 8mm. Check that your tools are not crappy. I saw a tool set once that had a 10.5mm socket that was labeled a 10mm :wink: . (wouldn't fit a 10mm or 11mm nut) All the other tool sets fit the same nuts just fine.
No kidding...
