bleed screw spanner size
AZ-3,1498cc,UK
Tried to open bleed screw on rear caliper to bleed the brakes, 8mm spanner not tight enough on nut will not turn, 7mm way to small! Have i rounded off the nut or do i need a special tool to open the screw?
V6 MX-3, Black, 17" gunmetal chromes with 205/40/17.
Now gone: Autozam AZ-3(Jap spec MX-3). 91, 1498cc DOHC 120bhp as standard. Manual, A.C, 17" black chromes with 205/40/17. Stainless Steel Exhaust,Pipercross Filter, Eco-tek valve, Strut brace, Racing steering wheel.
- PATDIESEL
It is a 7 or 8mm. Check that your tools are not crappy. I saw a tool set once that had a 10.5mm socket that was labeled a 10mm
. (wouldn't fit a 10mm or 11mm nut) All the other tool sets fit the same nuts just fine.
No kidding...
No kidding...
