Few electircal problems maybe?
- solo_ryder
I got a few electric problems i think. When I press in my brake pedal the interior lights flicker and so do the headlights for a split second, I am pretty sure this is caused by a dying ground connection...any input on what ground this is?
Have a look at these diagrams here,
http://www.mx3er.com/Info/1992%20Wiring%20Diagrams.pdf
On pages 2 and 3 there is a list of your ground points. The ground points are labelled on each drawing for each device so it will give you somewhere to start. For example the ground point for the stop lights is point "M", Figure 10, Grid B39.
Take careful note from Figure 6, Grid E20 what the brake light switch powers up when depressed.
