Turning Signal Troubles
kp2t
Post by kp2t »
when i put my left indicator on it makes the fast clicking noise, and shows no light on the indicator... i changed the front bulb and rear bulb but same situation, is it possible the bulb is just blown in the dash?
Corso
Post by Corso »
if youve checked all the bulbs and that still flashes fast its probably your signal relay, i had the same problem, its the little box under the dash next to the clutch i got one at a pick apart for like under $20 and it fixed all my signal problems. good luck.
relisys_3200
Post by relisys_3200 »
I agree...check the TNS relay under the dash. Located by the wire colours going to it (RED / BLACK, WHITE / BLACK and ORANGE). This happened to me too.
Brandon
1992 MX-3 GS-ZE
Grants
BANNED Member
Post by Grants »
relisys_3200 wrote:I agree...check the TNS relay under the dash. Located by the wire colours going to it (RED / BLACK, WHITE / BLACK and ORANGE). This happened to me too.
The TNS relay doesn't have anything to do with the signals. If the light on the dash doesn't flash fast it could be that one is blown. If you could swap the YELLOW and GREEN wires over at the flasher unit it would prove if it is the control circuit or the actual load. (This would make left come on when you indicate right and vice versa so don't forget to swap back straight away.)
relisys_3200
hmmm....This was the exact same problem I had and after fire and all it was the TNS relay that it was all traced back too. Maybe other things blew that were fixed that I didnt know about :shrug:
Brandon
1992 MX-3 GS-ZE
Grants
BANNED Member
Post by Grants »
The TNS relay does the tails, dash and parking lights (?). It also sends a signal for that damn beeping....
jschrauwen
Post by jschrauwen »
Grants wrote:that damn beeping....
I like my beeper, saved my battery a number of times ... LOL
kp2t
Post by kp2t »
80 dollars later and a new flasher relay got it all better
jschrauwen
kp2t wrote:80 dollars later and a new flasher relay got it all better
:shock: :shock: :shock: I don't think I want to buy parts from that place. $80 for a $5 part, hope it's made of gold or something :shock: .
neutral
Post by neutral »
Not positive on this but if memory serves, I think the Mazda TNS flasher relay is unfortunately not one of those $5 replacement types. Seem to remember that the dealer price for the replacement part is ~$100? :shock:
Image -Jim
The flasher went on the 626 back when I was driving it before I got the Mx-3, it was $60-something back then, dealer only part too. Not cheap, especially since they don't allow returns on that part, but it fixed the exact same problem that you had Kp2t
hgallegos915
Post by hgallegos915 »
i got mine for 10 dllrs of a scraps yard
-hec
kimlin85
Post by kimlin85 »
both my front driver signals don't work, ya know the bumper and the sidemarker. i had a shitty bulb that broke and i saw a spark. did i short something out? wtf should i do? pooooop.
raspberry metallic 2.5 klze, clutchmasters stage II clutch, ss autochrome headers, kl31 ecu, magnaflow cat, twm shortshift, corksport rear strut tower bar, clear turnsignals, and lots of dents.
