Sidelights just won't work.
Zartori
Post by Zartori »
Hi
I've been reading the forum looking for a silmilar problem to mine, but I don't think I've found the answers I've been looking for.
The problem is I have no sidelights on one click, on 2 clicks I get all lights on (heads, sides, tail, plate) an interesting thing is my dashlights are quite dim, if I switch on the fogs the dash lights go completley out. Also all fuses are fine.
So could it be an earthing problem? relay problem?
Thanks in advance...
Oh and it's a U.K MX-3
Grants
BANNED Member
Post by Grants »
Hi there and welcome!
For the dash lights I'd try bridging out the dimmer temporarily and see if that works. Have a look here:
http://www.mx-3.com/phpbb2/viewtopic.ph ... mer+bridge
and
Or it could very well be grounding, but try the above first.
As far as the side lights, it could just be the switch..
