Valve Body - rebuild or replace?
I'm considering 93 GS, and know for certain it's has a bad valve body, which isn't allowing the transmission to work. Has anyone had experience with this they might care to pass along?? I'd appreciate it!!
If not broke - don't fix, modify. If broke - fix it right, and make it better.
Mr. LeMans
Re: Valve Body - rebuild or replace?
I have built over a 1000 of these, there are some good mods you can do for line to lube and so forth if you need help please e-mail.
