code 69 woes(look again)
Well since I bought the car I have gotten a code 69 that swapped with the engine when I used the old throttle neck. I replaced the sensor (special order? $40) that didn't fix it. Any ideas would help greatly. Thanks.<BR>Shawn<p>[ November 27, 2002: Message edited by: lazzyie ]
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
pelado
Re: code 69 woes(look again)
My list of codes doesn't go that high.<P>You an OBDII man?
92-93 had the sensor, is the one by the water inlet its green, the manual is telling me to throw away my ecu but the k8 did it too, im just about to shoot it
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
pelado
I'm lost, what page is the code on?
white fish
this might be a joke code "69" fun code
no its not a joke thanks though... hmmm mazdamaniac.com, jeff abrams site, code 69 is page f2-78, f2-96, it does exist, David has the book too!!!!
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
TTT so gay but I need help!!!!!
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
