having a problem..please help
whitestevemx3
I recently bought a 92 MX3...and i paid 900 for it, b/c it had a bad tranny, so i bought a new tranny, and put it in....Now i go 2 drive it, and the thing wont move. Me and my buddies have discovered that its w/ the fuel relay system, but the fuel pump, is puming, and the fuel filter is filtering. I'm thinking sumthing is wrong w/ the injectors, or maybe the fuel pressure regulator?...I'm so confused, but if any1 could help me i would be extremly happy
ummm, yeah...gimme a couple months
Re: having a problem..please help
What is your car doing?? Does it stall when you give it gas??
whitestevemx3
Yes thats exactly wut happens...unless we spray gas straight into the throttle body, then it stays running until we stop spryaing the gas in...can u help?Originally posted by Taillon:
im doing all of the work on this car and i am baffled, all i can think of now is just replacing things one by one until i fix it,so please help us out before i turn to that. we've been at this nearly a week on all of our free time, get me out of this mess.
the car starts, and when you touch teh gas it stalls, sometiems you can get it to run a little while but it wont run on its own mroe than five minutes.
thanks guys.
Jason.
thanks guys.
Jason.
24 valves.
6 cylinders.
1 driver.
6 cylinders.
1 driver.
perhapsadingo8yerbaby
You guys are gonna want to kill yourselves if the prob is what I think it might be, except you'll be glad to catch it now if this is the cause.
Anyway, I once had the EXACT same set of symptoms (and conclusions) on a 90 MX6. After replacing the expensive VAF w/no improvement I was convinced it was the fuel pump or maybe fuel system relay. But nope, plenty of gas getting thru. Problem turned out to be hairline cracking of the stock rubber intake boot/hose that connects between the VAF and throttle body. The cracks were deep down between the ribs of the bottom side of the boot and not visible without removing the boot and flexing it. I did a quick patch with duct tape until I replaced it. Sounds so simple yet it's easy to see why it looks like a fuel supply issue cuz as soon as ya give it gas, those cracks allowed way to much unmetered air to be drawn in and the engine could not possibly draw enough fuel to match the leaking/inflowing air to the TB. Dunno if that helps but worth a look if ya haven't ruled this cause out already.
Ya to me it sounds like the Mass Air Flow senser!! Check to see if it is pluged in, or if possible try someone elses, because if you werent getting any gas to the engine it would not run at all....check the MAF to see if it conected, and look to make sure you have it going the right way! If it is not that i would think it would be the feul pressure regulator!! Good luck
checkign that stuf today....any other ideas?
ive looked at all of that but a second look and borrowing an maf wouldn't hurt
thanks,
Jason
thanks,
Jason
24 valves.
6 cylinders.
1 driver.
6 cylinders.
1 driver.
Sounds then like all the basic visual check stuff has been covered. Yeah, try swapping to a borrowed VAF you know is good. If that doesn't nail the prob, need to pull the engine trouble codes and see what ya get. Til then, you'd be shooting in the dark, spending lots of time and possibly cash for parts you probably don't really need, and slowly losing your sanity and maybe even your very will to live...
whitestevemx3
anyone kno if it could be the fuel pump...b/c it starts, and then like 10 seconds later it shuts off....thats where were at right now...post if u can help
- ryanlindenberg
pull the fuel line from the fuel rail...put it into some kind of container and turn the car over...if your pump is working quite a bit of gas should be comming out.
CARDOMAIN WITH UPDATED PICS
- Casino
loss of vaccum somewhere maybe ?
i kinda had this problem the car would start run for like a couple mins then die. it had something to do with one of my vaccum lines.
i doubt its something like that but im just throwing out ideas
