Brake lines that are stuck
- Josh
Re: Brake lines that are stuck
yes. You will need a flaring tool. They are about 20-50 bucks. You would cut off the end and slip off the stripped out fitting and slip on the new one. Then you would flare the end. Most have a lot of difficulty flaring brake lines especially old ones. if it cracks you have to start over. I would recommend buying a section of line (its like 4 bucks at NAPA) and practice first.
I just went through replacing all of the lines that run from the front of the car to the rear due to corrosion. Those two brake lines run straight from the proportioning valve on the dash panel behind the engine.
The lines are not expensive but really - REALLY difficult to swap. If you can re-flare new nuts THAT is the answer.
1993 GS SE - "slow" (Stock) - SOLD
1993 GS SE - "fast" (Curved neck KLZE, OBX headers, custom 2.5" exhaust, KL36 ECU, Exedy Probe GT clutch, KL36 LSD - the real one, Lantis Type R lefthand halfshaft - unfortunately worth mentioning)- SOLD
1993 GS SE - acquired 4/28/2013, SOLD February 28, 2015
1985 RX-7 GSL-SE - SOLD
2003 VW GTI 1.8T
2009 Mazda5 Grand Touring
2003 VW GTI 1.8T
