[WTB] Rear polyurethane bushing kit
Looking for an Item you'd like to buy? Post here.
This section is NOT for selling.
stereoking15
Post by stereoking15 »
Looking for a rear set of poly bushings for the rear on a GS looking for 80 durometer or greater. I dont mind if they are new or a good used set. I want the ones like what Wytbishop had for sale. shipping would be to Portland OR, 97236.
Thanks in advance.
94 gs ze swapped,front mount oil cooler,b&g springs, kyb gr2 struts, vris deleted, gutted, racing 4 point harness. centerforce dual friction clutch, BREMBO ROTORS X4, CARBOTECH XP10 front pads, ebc green stuff rear PADS, corksport brake lines & clutch line, hei mod w/ msd blaster 3, MAZDASPEED motor mounts, B&M short shifter, M-FACTORY LSD, Carbon fiber hatch with lexan window.
stereoking15
Re: [WTB] Rear polyurethane bushing kit
bump
stereoking15
bump
MrMazda92
Post by MrMazda92 »
I have an Energy Suspension polyeurethane set for the TTLs. You would need to clean up the sleeves inside of your stock bushings in order to use them.
stereoking15
Clean up how? What are you asking price wise?
MrMazda92
Post by MrMazda92 »
The sleeves that come inside of the Energy bushings have too large of an inside diameter, so there is slop between the TTL bolts and the bushing. The outside diameter is IDENTICAL to the stock bushing sleeves, but you will need to melt the rubber off of the stock sleeves, and then clean them up with a wire wheel or similar, so they can fit inside of the Energy bushings.
I'll try to find out whatever the price is from the retailer, and then knock off 30% for you. How does that sound?
stereoking15
Well I work for Baxter auto parts part time and get things for 10% above store cost, maybe we could work together on this you find the part #'s and I can get you some good pricing.
MrMazda92
Post by MrMazda92 »
I believe I posted it in my worklog, but honestly hate the idea of searching right now... :( Exhaustion really has a way of making every day tasks seem arduous
Return to “MX-3 Related Want to Buy Forum”
