door weatherstripping
mikeinaus
Post by mikeinaus »
has anyone bought these recently? i found some old threads saying mazda was charging under $50 each side and was wondering if current prices should be accurate to that? i called a local mazda dealer and they want $100 a side. i know stock is probably running low for them but wouldnt they charge less as less people are driving these cars?
Re: door weatherstripping
mikeinaus wrote:i know stock is probably running low for them but wouldnt they charge less as less people are driving these cars?
No, until they go into a discontinued status...
If you have a part number use these guys (cheapest OEM mazda parts I have found): http://www.onlinemazdaparts.com/
What about a junkyard?
mikeinaus
Post by mikeinaus »
Most of the ones I've seen in junk yards are usually trashed. And id love to get back that nice "thud" sound u get with newer cars. I tried searching for that thread with all the weatherstripping part numbers yesterday but I couldn't find it. If I can comeup with the number ill give that site a look. Thanks moon.
mikeinaus
Post by mikeinaus »
found it! viewtopic.php?f=17&t=69775
does anyone know if i want the door seal or the door weather stripping? i want the big rubber part that attaches and surrounds the door.
ethand
Post by ethand »
Hey mate, the last post on that link says:
onlytrueromeo wrote:Just to update, the door seal is a piece of molding or something, the door weatherstrip is the actual rubber piece that goes all the way around.
So I take it that you're after the weather strip...
When you say it goes all the way round, is that the little flappy bit that goes around the outside of the door, starting just below the window & going all the way round from there? Does anyone know if these seals are the same part number for JDM Presso's as with US MX3s?
'92 JDM Eunos Presso - Zeke
mikeinaus
Post by mikeinaus »
they should be. i ordered a set from this guy http://www.ebay.com/itm/170677836261?ss ... 1497.l2649 they should come sometime this week. ill post when they arrive and let you know how install went.
mikeinaus
Post by mikeinaus »
it arrived today and it was totally worth it. my drivers door feels brand new. i can slam the door and its not even loud, just a nice thud. anyone know any tips for keeping the weatherstripping in good shape? other then not slamming the door that is. i think the main problem is the weatherstripping looses its rigidity over time and stops cushioning properly. my new set was quite a bit "puffier" then my old one.
ethand
Post by ethand »
Awesome, so glad to hear it was worth it :)
I don't think its really possible with rubber - it's a perishable material, and it always deteriorates with age. I think extremes of heat/cold probably don't help it last any longer, but with a car, it's hardly possible to protect it from that...
DeepBlueMX3
Post by DeepBlueMX3 »
mikeinaus wrote:they should be. i ordered a set from this guy http://www.ebay.com/itm/170677836261?ss ... 1497.l2649 they should come sometime this week. ill post when they arrive and let you know how install went.
Is this for the right side only?Does haven't him the left side???
MX-3 B6ZE Noble Green
mikeinaus
Post by mikeinaus »
yeah it was the drivers side. i didnt look too much for the passenger side as mine is still in fairly good shape, but the 5 mins i did spend i didnt turn up anything...
DeepBlueMX3
Ok, I order one too... Thanks :D
mazdaspeed23
Post by mazdaspeed23 »
i was going to by some new ones. and mazda wants $19.00 for the front window, $38 for the back. and $99 for each door
Own
1994 MX-3 GS swapped ZE
1994 MX-3 GS Swapped ZE (Gone)
1996 Dodge Dakota Sport v8 Magnum
2007 Ford Fusion SE
WORK LOG: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=81232
My MX-3 is nothing without me, and i am nothing without my MX-3
MrMazda92
Post by MrMazda92 »
Mark, you're a genius!
I've been looking for THIS forever!!! #7 on this diagram, btw!
mazdaspeed23
im looking for some aswell, i called my local mazda dealer 2 weeks ago, they want $99 for each side. and $50 for the windshield
Own
2007 Ford Fusion SE
kulluminati777
Post by kulluminati777 »
sounds about right for some reason these rubber pieces are expensive
Return to “Appearance”
