mazda mx3 obd
mazda mx3 obd
Hi to all, I am new in the forum, I have a question, it's possible connect mazda mx3 with obd to pc?
this is the mx3 obd? http://z.about.com/d/autorepair/1/0/T/U/42129986.gif" onclick="window.open(this.href);return false;
it's possible to read with software on pc the rpm,error,ecc...?
thanks to all
escuseme for my bad english but I am italian
thanks to all
93' MX-3 1.8 v6 K8
- fowljesse
Re: mazda mx3 obd
Ciao!
If your car is newwer than 1996, and you have the software, you can use the computer diagnostic program.
Re: mazda mx3 obd
my car is a 1995 mx3, I can use the computer diagnostic program with this?fowljesse wrote:Ciao!
93' MX-3 1.8 v6 K8
Re: mazda mx3 obd
No, that's the Mazda Diagnostics Port, OBDII is a standard, you should have something under the dash that looks like this:andrea89 wrote:this is the mx3 obd? http://z.about.com/d/autorepair/1/0/T/U/42129986.gif" onclick="window.open(this.href);return false;
There's probably a 80-90% chance that your car is OBDII. Only the '96s are 100% (mandatory) OBDII
Re: mazda mx3 obd
I haven't find this port in my car under the dash,please you can show me a photo of the complete under dash and you can draw obd position?, so I can see where is the obdNd4SpdSe wrote:No, that's the Mazda Diagnostics Port, OBDII is a standard, you should have something under the dash that looks like this:andrea89 wrote:this is the mx3 obd? http://z.about.com/d/autorepair/1/0/T/U/42129986.gif" onclick="window.open(this.href);return false;
very very thanks
93' MX-3 1.8 v6 K8
- RS_OBD'oh_2
Re: mazda mx3 obd
lay on your back on the passanger side floor. Look up and towards the center it should be just past the dash. The idea of the OBD2 port is that it must be able to get at with out removing any trim. Get a flashlight incase you have low light. While you are under there take a look at how many plugs you have in your ecu.. that'll tell ya too.
Re: mazda mx3 obd
my ecu have 3 plugsRS_OBD'oh_2 wrote:lay on your back on the passanger side floor. Look up and towards the center it should be just past the dash. The idea of the OBD2 port is that it must be able to get at with out removing any trim. Get a flashlight incase you have low light. While you are under there take a look at how many plugs you have in your ecu.. that'll tell ya too.
93' MX-3 1.8 v6 K8
- marcdh
Re: mazda mx3 obd
Both my mx3s are OBDI, 1995 date of registration. You have to remember the car was manufactured, shipped, sat on a forecourt/stored, then sold. Both my '1995' (on the books) were infact manufactured in late 1993.
Your car is most likely OBDI Andrea. If your dash does not have a CEL (check engine light), as UK cars do not, then you need to do this: http://uk-mx3.com/forum/viewtopic.php?t=1463
View Worklog
View Worklog
Re: mazda mx3 obd
thanks for the answers,marcdh wrote:Both my mx3s are OBDI, 1995 date of registration. You have to remember the car was manufactured, shipped, sat on a forecourt/stored, then sold. Both my '1995' (on the books) were infact manufactured in late 1993.
yes is manufactured in 1993, I have the check engine light, but the obd port for connect to pc where is? or the 1993 havent this port? I have disassembled trim, dash , I have see under the passenger side ecc.. , but I have not find obd port with 16 pin
93' MX-3 1.8 v6 K8
- RS_OBD'oh_2
Re: mazda mx3 obd
then you have your answer.. it is not obd2andrea89 wrote: I have not find obd port with 16 pin
Re: mazda mx3 obd
the my mx3 have the obd1? where is?how much pin have the obd1?how I can connect it to pc?RS_OBD'oh_2 wrote:then you have your answer.. it is not obd2andrea89 wrote: I have not find obd port with 16 pin
93' MX-3 1.8 v6 K8
Re: mazda mx3 obd
You can'tandrea89 wrote:how I can connect it to pc?
Re: mazda mx3 obd
ok, thanksNd4SpdSe wrote:You can'tandrea89 wrote:how I can connect it to pc?
(it's possible to install a obdII port?)
93' MX-3 1.8 v6 K8
Re: mazda mx3 obd
It's not just the port, it's the whole computer and the wiring you would need to change. ODBII is the ECU which is a universal standard while OBDI is to each manufacturer.
http://en.wikipedia.org/wiki/OBDII" onclick="window.open(this.href);return false;
