ANOTHER PROBLEM :(
- johnmx3ze
ANOTHER PROBLEM :(
i have an other problem
is it possible that when im at full boost it kind of cuts... could it be because im still running the stock fuel pump or its something related with the spark plugs (fire) or what could it be...
Re: ANOTHER PROBLEM :(
What are you doing to add fuel?
What is your plug gap at?
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
- johnmx3ze
i only have an fmu and my plugs are the same as when i was all motor... do i have to change that?nos92mx3 wrote:What are you doing to add fuel?
- fowljesse
It takes more spark to jump the gap in higher compression, and at high rpms the stock coil probably can't recharge itself with enough power to keep up. MSD 6A would solve that problem. Make sure your ignition system is always perfect.
Drop the gap on the plugs down to .032, but first i would fix your fueling issue.
since your running an FMU without atleast a booster pump, or a walboro, that would be another one of your problems.
93' Rs-t BPT - Sold
93' Rs-t BPT - Sold
- johnmx3ze
so today i bought new plugs and gapped them to 0.30 and the car run very good no more cutting or nothing and the sound of the W/G when it opens is crazy lol... i hate to say that but it sound like a VTEC lolll...
hgallegos915
WHat does the wideband say?
Plugs need to be gapped lower but you have to go with what the wideband says.
I Have my plugs gapped at stock n/a specs and mine runs fine.
I Had to gap em lower once but then I found out I had a vac leak in the im that was only pressent during boot, well boost leak.
Also my friend leo.. with his boosted k8 and fmu. Yeah he blew his engine for the third time.
-hec
i now run my 1 step colder ngk iridium plugs at stock bpt gap. I had lessened the gap yrs ago to prevent the spark blow out from too much boost but since then I have tuned many things.
