CD Deck won't slide all the way in
Anyone else have that problem? I have a Pioneer DEH-P2900MP and it doesn't want to slide all the way in. It's been like this for a while but never got around to figuring it out. I tried moving the wires behind the player but still not enough room. The Pioneer is a pretty standard size deck how come it won't slide all the way in?
94 mx3 rs
Re: CD Deck won't slide all the way in
Is it hitting something in the back?
neli_nael wrote:Anyone else have that problem? I have a Pioneer DEH-P2900MP and it doesn't want to slide all the way in. It's been like this for a while but never got around to figuring it out. I tried moving the wires behind the player but still not enough room. The Pioneer is a pretty standard size deck how come it won't slide all the way in?
Dude my pioneer is the same way, i just deal with it. If you find a solution please let me know.
<a href="http://www.fodey.com/generators/animate ... .asp"><img src="http://r3.fodey.com/117ef9486659942269d ... 7601.1.gif" border=0 width="404" height="110" alt="Ninja!"></a>
I have a pioneer just not installed yet. I'm sure it will do the same thing. If you find a way to fit it in let me know. I'm gonna try my hardest to get it to fit all the way.
- Ryan
Could it be the tabs from the anti theft metal cages?
My 8400MP and 980BT both fit fine...
dont know, haven't had time to look at it. but will have time this weekend. let me know if you figure it since you're putting in yours also.coltfoet5 wrote:Is it hitting something in the back?
yes i have been looking at mine for a good 3 months, i'll let you know when i figure it out.Stablo87 wrote:Dude my pioneer is the same way, i just deal with it. If you find a solution please let me know.
do you mean the metal cage that came with the cd player?Ryan wrote:Could it be the tabs from the anti theft metal cages?
94 mx3 rs
- MX3-Life
This happens to me everytime i take it out but if you just jerk it around and then put it in with the front lifted up and the back pointed down and push hard it will go all the way. Just jerk it around and push hard
always works for me.
- Dali
unless you have the mounting screw put in the deck its just the wires. ive had many different decks and screens mounted in the car and the wires/rca/fuse holders allway get in the way. pull the panels off from each side of the center console (the ones by your feet that cover the ecu) and you can barely get your hand in there to help pull this stuff out of the way while you push the deck in. i found the top half is easier to mount stuff into but i have my cd player on the bottom, does not matter too much at all.
1993 White gs klze.
Put my Pioneer in and it hits in the back. It is sticking out about half an inch. I'm going to try to bend that bracket in the back and see if that works.
Actually working on Kp2t's car, I remembered I cut that vertical plastic part at the back. After just searching around for something unrelated, I found out I cut that out back in 2003!
Quote MX-3 Life wrote: This happens to me everytime I take it out but if you just jerk it around and then put it in with the front lifted up and the back pointed down and push hard it will go all the way. Just jerk it around and push hard always works for me.,,,,???
You guys need to stop bragging about your Decks size. Measure from end to end then measure your Deck. If it's too long then either have the slot deepened or leave a little of your Deck out. Trying to force it in further than the slot can handle does nothing but aggravate the situation. Thats my take on it.
sorry for being immature but that made me laughDaninski wrote:You guys need to stop bragging about your Decks size. Measure from end to end then measure your Deck.
94 mx3 rs
- Savin
Oh, you KNOW Daninski was having a good laugh while writing that! Definitely a reference to something else perhaps?neli_nael wrote:sorry for being immature but that made me laughDaninski wrote:You guys need to stop bragging about your Decks size. Measure from end to end then measure your Deck.
'93 MX-3 GS - SOLD!
'93 MX-3 GS SE - Parts car!
'94 MX-3 GS - Scrapped
'94 MX-3 RS - Scrapped
'96 Sunfire SE - Scrapped
'03 Sunfire SE - Deathtrap
'95 Cavalier Base - Scrapped
'89 Mustang GT - SOLD!
'93 MX-3 GS - SOLD!
Sorry forget to mention the use of some kind of lubricant to assist in the sliding in of the deck. Armoral would probably do the trick, I prefer the gloss shine myself
Apply liberally to the receiver and the sides of your deck. There may be some resistance intially but once you get the first 1/3 of you deck in the rest should just slide in with minimal effort. Remember technique works far better than brut force.
