SAFC 1st Generation - MX-3
ModMX3 - (Carmaster2005)
Post by ModMX3 - (Carmaster2005) »
Anyone know where I could find info. to the settings to select on the back of my SAFC 1 , Like the type select and car select for a 94 mx ?? As apexi dosent have the mx listed on their site. I have allready did many searches with no info about the safc 1. Thanks !
Apexi Safc 2 ,Timex Boost-Temp-Oil Gauges, Stage 1 Performance clutch, 8.5 mm Magnacore plug Wires,2.5 inch exhaust, Cold Air Intake , Short Shifter , High temp rotors & Ceramic pads to slow it all down !
BuGS
Post by BuGS »
Settings will be the same as a SAFC II. But look at the Miata. You have the same Hot Wire Sensor, and as far as the other ones, 4cyl and TPS sensor is Up, maybe...
Return to “Forced Induction”
