I have been looking for the link to reset and read the ECU codes, but (while its probably me just being blind) can't seem to find them on the site. Anyone able to link them for me?
The engine has about 120k miles (180k km) on it. The stall out from speed has been happening since I got the car in 99, but the rough idle is new(ish) and has only been happening really since I had it off the road in Oct 05. I need to know how I could narrow down and fix the idle problem but fixing the stall out would be a real bonus.
The possible candidates I have come up with for this are the idle bypass being partially or completely blocked, the TPS being faulty (though it was fine when checked in the past), the lambda or MAF sensor being duff or a vacuum leak.
I am going to give the TB a good cleanout this weekend (and hope I don't have to replace the internal gasket, because getting parts for this engine in the UK is a nightmarem, and expensive nightmare). Can that gasket be reinatalled with gasket cement if need be? I know that the butterfly needs to be reset as it sticks overnight pretty much all the time. I gave the bore of the throttle body a clean while I had the intake off to do the clutch, but the butterfly still sticks so probably best if I recalibrate it after the thurough clean.
I don't really know anything about testing the lambda sensor so any tips would be appreciated.
I was talking with some guys and they were saying that after a couple of years of running with a wet filter that their MAF (hot wire) got coated with oil and failed. I have been running a K&N wet cylinder filter for about 4 years now (though its probably about due to be re-oiled). Has anyone else had any problems like this? The question I most want answered is whether or not its advisable to clean a hot wire MAF with a blast of clutch or intake cleaner, or is this likely to damage it? Again, I don't know the test procedure for the MAF. Is there isn't much in the service manual that I have been able to find about it.
I think I found a small split in the hose from the crank case to the intake (the one that connects to the intake between the MAF and the TB) but I wouldn't have thought that would have caused a serious vacuum problem? I will try and find a replacement for that hose though just in case. I'll also give all the vacuum system a clean out. Are there any special tricks like pipe cleaners and/or clutch or intake cleaner, or is just checking that they blow through good enough? Also, what about the actuators and the charcoal cylinder? Do they ever get blocked/break, and how would you clean them (if its even possible)?
All in all I think my saturday is going to be a busy one and I hope nothing goes wrong because I can't afford to have the car off the road.
If anyone can think of any other things I could/should check then I would be interested in opinions.
