Turbo Setup Finished
ModMX3 - (Carmaster2005)
Post by ModMX3 - (Carmaster2005) »
Thanks to everyone who help me with questions. I just got my car back today from the shop (to weld the downpipe to the rest of the exhaust) and i decided to see what it could do all i can say is :D ,turbos are so cool! this car pulls strong! no overheating no leaks no problems. The only thing I noticed is my clutch is not strong enough (clamping force) to hold all this power now. its a stage 1 , felt very strong befor the turbo but now it slips. guess i will have to upgrade to stage 3 any one have any reconmendatons ? also a Note to everyone looking for an aftermarket BOV the HKS SSQV is really loud ! schould have went with the rfl, not that hks sounds bad its just so freaking loud.
Apexi Safc 2 ,Timex Boost-Temp-Oil Gauges, Stage 1 Performance clutch, 8.5 mm Magnacore plug Wires,2.5 inch exhaust, Cold Air Intake , Short Shifter , High temp rotors & Ceramic pads to slow it all down !
XxantwawnxX
Post by XxantwawnxX »
it is loud, thats why i love it : )
Return to “Forced Induction”
