WasteGate Venting
nolig2278
WasteGate Venting
Post by nolig2278 »
Does the wastegate vent exhaust fumes?
If so, where and can it be rerouted?
94 RS to BPT
2.5 FMIC
MicroSquirt
2.5 Exhaust
[url=https://gilon.levinsonltd.com/mx-3.html[/url]
cjthor
Re: WasteGate Venting
Post by cjthor »
nolig2278 wrote:Does the wastegate vent exhaust fumes?
The Wastegate is used to control exhaust gas pressure to make boost. It should be routed back into the exhaust roughly 12 inches down the exhaust downpipe. Some people run a seperate exhaust pipe for the wastegate.
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
Rick Johnson
Post by Rick Johnson »
It vents fresh air, so into the interior of the car is best. I run mine thru the firewall grommet on the driver side. :2thumbsup:
Bochek
Post by Bochek »
rotflol, better watch he doesnt beilieve you and kill himself.
Bochek
Adam Bochek's 93 1.6L SOHC http://www.bochek.ca/car.gif
nolig2278
Post by nolig2278 »
Where is the hole that vents to lower pressure or does it vent internally?
I fully understand how it works as in I know wastegate relieves some of the exiting exhaust fumes in order to cut the speed of the turbo.
Rick you are an a--.
94 RS to BPT
2.5 FMIC
MicroSquirt
2.5 Exhaust
Return to “Forced Induction”
