Hi,
I have a intermitent rattle from the hatchback.Its driving me crazy.
I`ve emptied the boot(trunk) took the parcel shelf out .and the noise is still there.Any ideas guys.
Noise from hatch
- Typhoonk
If you look at the panels that are around the back seats. There are plastic inserts that just clip in. I found four of them. And removed them and it stopped the anouying rattles. So I just used a style of playdo stuff (high heat), and then put em back in.
PM for info
PM for info
- neutral
Re: Noise from hatch
Ck your center brake light housing too. Mounts with two bolts that can loosen over time. Drove me nuts for a month or two til I could tell where the rattle was. There was also a Tech Svc. Bulletin from Mazda on repairing a rear hatch/hinge prob w some '93 MX-3's. http://mx-3.com/tsb/s047-93.gifpeteuk wrote:Hi,
-Jim- jschrauwen
It may be your jack which is in the right rear behind the removeable panel as you look at the hatch from the rear. It may come loose from it's perch and just has to be expanded to sit tight again. Hope this helps.peteuk wrote:Hi, I have a intermitent rattle from the hatchback.Its driving me crazy. I`ve emptied the boot(trunk) took the parcel shelf out .and the noise is still there.Any ideas guys.
