Shawn i think your question is can KLZE piston's be put in a KLDE
the answer is No! Sorry clearance issues.
klze intake ports
Gro Harlem
this should explain any confusion:
left is stock klde, right is klze. notice the dish?
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Gro Harlem
uhh....where do you get your information?kiwi_MX3 wrote:Shawn i think your question is can KLZE piston's be put in a KLDE
why would there be clearance issues? the stroke is identical, the camshaft lift is probably less on the KL01 cams, so how would that make the pistons contact the valves?
I know of MANY probetalk guys running KLZE Pistons in their KLDE engines with no issues.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
