Does any one know what the problem might be, and if so how can i fix it, any help will be much appreciated.
Lost Gear
Lost Gear
Hey, about two months ago i was having problems with my clutch, for example it wouldn't go into gear as easy and finally the clutch went limp, i found out that it was the clutch fluid hose that broke and it was easily replaced, but after I replaced the hose the fifth gear just seemed to vanish, it's as if there is nothing there anymore. At the time I didn't mind it because I never really used the freeway but now i am working at a different location and i really need 5th so i don't waste gas(I would also like to test my top speed
92' MX3 GS teal, mazdaspeed air intake, 15' Konig rims...soon to put about 6k into entire car, engine and exterior.
- MX3parkerGS
no clue, but my friends 93 pgt once lost 3rd gear, we had no clue either, so he went about a month or two w/o it then outta nowhere 3rd gear was back! ever since then i thought he car was cursed or somthing :p
'94 White MX-3 GS. Engine bay empty and waiting for the 2.5DE.
Completly stock, at this time.
Parker
Parker
TsiMiata
You probably bent the shift fork for 5th gear when the clutch went. If you ere forcing it into gears all the time as the clutch went away over time. If it's grinding then it might be synchros. How does the shifter feel- sloppy or tight?
91 Eagle Talon Tsi AWD *RIP*
