Need photos/diagram/guide to wiring harness after KLZE swap
Posted: January 15th, 2016, 5:21 pm
by JeffB
The engine swap I started long ago with the help of a neighbor who's not around anymore is now practically done. The KLZE engine cranks and starts (and sounds nice!). Unfortunately, because I am an idiot, we did not label the wiring harness when we disconnected everything to yank the old engine. Can anyone out there point me toward a clear diagram? Or take detailed photos of their own K8 or KLZE so I can maybe see what goes where? Or is there another MX-3 anywhere near Washington, D.C., that I can look at?
Re: Need photos/diagram/guide to wiring harness after KLZE s
Posted: January 19th, 2016, 12:38 pm
by Nd4SpdSe
Did you do a standard fuel and spark check? What you running for disty?
Posted: January 20th, 2016, 5:18 pm
by Daninski
Each plug is unique so it's a no brainer for the most part except the anti knock sensor wire routing changes. 96-97 the co monitor plug is the same as the fuel rail plug so anyone watch out for that. :oops: My car is stored for the winter so I can't help there but there should be lots of pic of engines on this site you can look at.
