key hole light
Posted: September 11th, 2015, 7:55 pm
by alvinlulu
i realized the key hole light is always on regardless even at night when parked ... any suggestions ?
Re: key hole light
Posted: January 3rd, 2016, 8:56 pm
by DeviousBaboon
I have the same problem on my '93 GS.... would like to get to the bottom of it as well..
Re: key hole light
Posted: January 4th, 2016, 3:12 am
by WhiteFinish
me 3
Re: key hole light
Posted: January 6th, 2016, 9:07 am
by Stefenwolfe
same here
Re: key hole light
Posted: October 29th, 2017, 11:45 pm
by toomanyangelz
be happy you have a key hole light some of use don't
Re: key hole light
Posted: October 30th, 2017, 11:49 am
by mitmaks
I think mine burnt out, should be a led light in there I think?
Re: key hole light
Posted: November 6th, 2017, 8:41 am
by Eric Hooper
I've had it out before, I believe that it's you normal dash light attached to the back of a clear plastic ring that acts kind of like fiberoptics. As for the problem of it never turning off that the others were having from years ago I would assume that if the dash light and main light go off when the doors shut whatever times the light must be at fault.
Re: key hole light
Posted: November 6th, 2017, 2:06 pm
by WhiteFinish
Eric Hooper wrote:I've had it out before, I believe that it's you normal dash light attached to the back of a clear plastic ring that acts kind of like fiberoptics. As for the problem of it never turning off that the others were having from years ago I would assume that if the dash light and main light go off when the doors shut whatever times the light must be at fault.
Nope, light remains on even though the doors are closed and locked
Re: key hole light
Posted: November 6th, 2017, 8:11 pm
by Eric Hooper
Ignore the clear plastic ring description, I realized this morning when I got in my car that I got my rav4 and mx3 mixed up. As for the timer thing what I meant was that because your dome light is working correctly that it might make sense that theirs either a timer or a relay that is not functioning correctly. I don't have a wiring diagram so it's just a shot in the dark.
I asked someone to look up the ignition light bulb number but they couldn't find anything, maybe it is an led. Its been since my last mx3 that I've had an mx3 column apart.
