So my reverse lights don't work so for temporary use I want to tap into an earlier point in to my reverse lights system in order to get the lights to work temporarily so I can pass inspection because its urgent
If someone can let me know where I can take the positive feedback from whether it be a line or a fuse to get a signal sense that would be great
Tap in to reverse lights
- wednesdayslatest
03 Dodge Neon (rental i had for a month but i ran that into the ground for sure)
95 Chrysler Concorde (Junked my first car [still ran])
90 Nissan Stanza (Junked [wouldnt start one day])
89 Saab 9000 CD (sedan/turbo very fun but electrical problems[city towed away for no plates on private property])
94 Toyota Camry (mothers old car fixed it then broke it[dont ask] Junked)
93 MX-3 RS (My project for 3 years so far)
97 Honda Civshit (Beater/Stereotypical POS Honda im fixing)
Re: Tap in to reverse lights
the reverse lights work off a sensor that attaches to the transmission casing.
The wires are prone to breaking off the sensor itself. Probably just need to replace the reverse sensor switch on the transmission.
- wednesdayslatest
Yeah I realized that after I went to look the connection was all green so I was going to cut it and redo it but it broke so I'm going to replace the sensor and try to find a way to make it so it doesn't break
- wednesdayslatest
But I do have a question it won't harm the system if I put the wires backwards to the sensor right it just won't work as long as I know it doesn't do damage if I connect it incorrectly I won't have a problem I just want to be sure because the sensor plug was cut off
- Ryan
The sensor has no polarity. Its just a switch. Doesn't matter which way the wires go in to it.
- wednesdayslatest
Oh the sensor was bad it so it was all green s--- all over it on both the connector on the sensor
Now my signal wire wont start the starter I'm just going to run a momentary switch from the battery to the starter for now I got the relay and I looked at all the fuses but I can't find the relay all the fuses should be good so I'm assuming it's the relay I really need to get into some electrical soon but its really cold I just need to start the car go get the e brake fixed and go pass inspection before my car gets towed out of my apartments so much for the American dream
