WTB: Working Auto Belt Upgrade or Manual Conversion
Posted: March 24th, 2014, 7:38 am
by gjogil
I would prefer to just go ahead and convert to a manual seat belt setup for both the driver's and passenger's side.
If a manual conversion isn't easy to source, I need a working driver's side auto belt setup, the whole assembly - track, wiring, motor, and cable spool system. I'd like that it come from a vehicle that has already had the recall service. I assume that they improved the design for better longevity and wouldn't waste time installing junk parts in a recall???
I would consider a working pre-recall setup as well.
Help! I don't want to get stopped for no seat belt and I honestly don't like the feeling of just the lap belt.
Re: WTB: Working Auto Belt Upgrade or Manual Conversion
Posted: March 24th, 2014, 9:01 am
by SuperK
Where are you located? Sunroof or no sunroof? The headliner needs to be swapped as well.
Posted: March 24th, 2014, 8:56 pm
by gjogil
No sunroof and I'm in Oklahoma. I would really rather not have to hassle with the headliner if at all possible. I read something about the trim being more narrow or wider without the seatbelt track and that's why it needed to be swapped. IF I could still convert without swapping the headliner, I just need a working seat belt and the aesthetics can hold off for awhile. Not to say that it's not important, I just don't have any show car plans for this gas sipper.
Posted: March 25th, 2014, 1:46 pm
by SuperK
auto seatbelt headliner is narrower than manual seatbelt headliner.
you will have gaps on the left and right if you use the auto headliner with manual belts.
