Passenger side window not working motor working
Chartin81
So got the car and the passenger side window was not working talked to previous owner and said the switch went out and Later said it sparked when he tried to put it down so thinking is a relay looked for a fuse but the one I found was good and driver side window works anybody have this problem I have since checked the motor and it works got another switch that is in tact but not positive it's working but seems to be thanks for any help
Re: Passenger side window not working motor working
Ok since you haven't given us any information regarding the model and year of the car I can only guess but if your car is a 02-03 and he replaced the window switch with an 04-07 then you'll need to do a mod on the switch in order to supply power to the passengers window. This of course is only a guess because (see writing in italics)
Use our search function and you should be able to find the post I'm refering to.
Ok I figured if you can't even give basic info you probably can't use a Search feature either so here's the info you'll need to tell if your switch is newer or older.
http://mx-3.com/phpBB3/viewtopic.php?f=44&t=66265
What, me be facetious,,,,never.
Chartin81
Sorry it's a mx3 website so I assumed we were talking about mx3's sorry it's a 1993 Mazda mx3 gs with the power windows looked for a schematic and coulnt find one sorry for the confusion lol
Hey no problem but just for your info in certain circumstances 92/93 are more or less the same, then 94 is an animal all on it's own when it come to ignition. Then 95 is very similar to 96/97 however 96/97 are both OBD2.Chartin81 wrote:Sorry it's a mx3 website so I assumed we were talking about mx3's sorry it's a 1993 Mazda mx3 gs with the power windows looked for a schematic and coulnt find one sorry for the confusion lol
Daninski wrote:Ok since you haven't given us any information regarding the model and year of the car I can only guess but if your car is a 02-03 and he replaced the window switch with an 04-07 then you'll need to do a mod on the switch in order to supply power to the passengers window. This of course is only a guess because (see writing in italics)
02-03 eh? 04-07 eh? YOUR GUESSES ARE WAY OFF.
Math was never your strong point.
What's one year or ten years?
- mitmaks
Have you removed door panel to see what happens when you activate window switch? Make sure track is not bent and there's nothing jammed in it that prevents glass from moving up/down. Can you open/close passenger window with switch on drivers side or neither drivers or passenger side switch movie it up/down?Chartin81 wrote:So got the car and the passenger side window was not working talked to previous owner and said the switch went out and Later said it sparked when he tried to put it down so thinking is a relay looked for a fuse but the one I found was good and driver side window works anybody have this problem I have since checked the motor and it works got another switch that is in tact but not positive it's working but seems to be thanks for any help
Don'tcha just hate it when you try to burn someone else and you just end up burning yourself?Daninski wrote:![]()
92-94 95-97
I'm just here to help not criticize peoples typo's. Do you have any thing positive to contribute here Mr K?
(Dan now awaits Kris's most invaluable suggestion for the repair of posters switch with no negative retort from him because we both know he's above such negativity,,,,or is he )
Contribute here? Not really. We chat via text often like good gossiping girlfriends. I offer him advice then try to peddle my wares on him giving him bunk advice just to make extra dough
That's why you are and always will be, my friend.SuperK wrote:Contribute here? Not really. We chat via text often like good gossiping girlfriends. I offer him advice then try to peddle my wares on him giving him bunk advice just to make extra dough
