broken pieces in mij intake cams full of cooling liquid
Posted: May 5th, 2013, 2:04 pm
by lucifernl
hi all.
i have a big problem.
coolant was comming out of my exhoust.
i took the valve cover off en everywhere whas cooland liquid.
i take my intake off and i find pieces of broken metal parts.
does sombody knows what this is broken off from?
also took my cams out for revision of the hla`s
found a broken 1
greetings kevin
Re: broken pieces in mij intake cams full of cooling liquid
Posted: May 5th, 2013, 2:42 pm
by RobMinhas
Wow, that broken valve spring retainer got wrecked.
And that piece found it's way into the top of the head? Are there any holes large enough to accommodate it? Was it jammed in between something when you found it?
The only holes i can think of that are big enough are the intake and exhaust ports so it seems your intake may have fialed and had that piece break and fall in through an intake port and where it broke a coolant line also ended up seeping fluid into it.
Posted: May 5th, 2013, 4:21 pm
by lucifernl
i found those pieces just a few cm in my intake right behind my trottle body.
Posted: May 5th, 2013, 4:39 pm
by RobMinhas
Ah I misunderstood, I thought the piece was found in the cylinder head not intake.
And I don't recognize that metal piece, is there any chance you might have sucked it in through your air filter?
Posted: May 5th, 2013, 4:50 pm
by lucifernl
the car was runing then i heard a breaking noise i shut the engine off and start looking then i found the metal pecies.
also 1 spark plug whas the tip hit and it whas bended not broken.
Posted: May 5th, 2013, 9:47 pm
by Inodoro Pereyra
RobMinhas wrote:And I don't recognize that metal piece, is there any chance you might have sucked it in through your air filter?
Which one? The one on his hand looks like half a valve seat. The one in the last pic is a broken retainer.
You gotta love Mazda engines. What other engine could ssurvive that damage?
Posted: May 6th, 2013, 4:16 pm
by WhiteFinish
I hope its not the valve seat...
would that be fixable ?
Posted: May 6th, 2013, 4:21 pm
by Inodoro Pereyra
Depends on what the damage is inside the cylinder. It's a safe bet that the heaad is probably scrap. I don't know about the piston and the cylinder wall...
Posted: May 6th, 2013, 4:31 pm
by marcdh
Belt valve stem for first one? Looks fairly catastrophic! Unlucky.
Posted: May 10th, 2013, 3:59 pm
by WhiteFinish
Today we took off the head...
Carnage...
Dropped valve, big hole in piston #6, cilinder heavily damaged
Cilinder #4 cracked about 1" down.
Posted: May 10th, 2013, 6:01 pm
by Inodoro Pereyra
Ouch!
I see a new engine in your future...
Posted: May 12th, 2013, 6:00 pm
by lucifernl
cilinder 4 cracked
cilinder 6 broken retrainer valve dropped
