BP swap or boost my b6?
Posted: March 8th, 2013, 8:42 am
by MazdaMan1991
so ive been thinking alot lately instead of boosting my b6, spending the same amount of money and dropping a bp in.... i just want some opinions :D
Re: BP swap or boost my b6?
Posted: March 8th, 2013, 9:45 am
by RobMinhas
BP, then boost the BP further down the road.
Posted: March 8th, 2013, 10:09 am
by MazdaMan1991
thats what im thinking cuz im sure i can find a decent bp motor for under 500$
Posted: March 8th, 2013, 10:54 am
by RobMinhas
MazdaMan1991 wrote:thats what im thinking cuz im sure i can find a decent bp motor for under 500$
I'd say slowly amass your parts for the engine while grabbing any aesthetic or suspension upgrades, no need to rush.
For the BP, you'll just need to source the engine, trans, axles, ecu, vaf and it may be worth it to grab the engine harness if you don't want to modify your own harness.
I htink you've already got an exhaust mani and turbo,s o just grab a fuel pump, intake mani, intercooler, upgraded injectors, IC piping, BOV, BPT ecu and a down pipe and you shoudl be set.
Posted: March 25th, 2013, 1:09 am
by monty73741
I say boost the b6. that is what i am doing, but I dont drag, auto cross or anything it is more of a hobby for me
Posted: March 25th, 2013, 10:22 am
by MazdaMan1991
Same here its my dd and I'm just boosting it for the fun of it
Posted: March 25th, 2013, 2:58 pm
by Josh
IMO both are great. A boosted b6de will yield 160ish wheel HP with the factory B6T bolt ons. Though, the BP realm has a lot more support. If I were to do it all over again, I would probably go with a BP. You can find them in the JY for 100-250, and much more options when it comes to turbos and Intake Manifolds. plus they produced the BP through 05' so support will be around for a little while.
Just my 2cents.
Posted: April 1st, 2013, 12:42 am
by RS_OBD'oh_2
both are good options. I do see a major issue with you boosting your DD. There is a fair expense, and down time when it comes to a build. I have plenty of fun in my b6 turbo. But only stuck with the B6 as my car is ODBII.
Posted: April 1st, 2013, 10:12 am
by MazdaMan1991
RS_OBD'oh_2 wrote:both are good options. I do see a major issue with you boosting your DD. There is a fair expense, and down time when it comes to a build. I have plenty of fun in my b6 turbo. But only stuck with the B6 as my car is ODBII.
right, the thing is I do have a fall back vehicle if anything goes wrong I just hate driving it lol
Posted: April 1st, 2013, 12:59 pm
by Josh
There are only issues if you can't get it running :) And you can strap a BP in your car all day long. They use the same sensors and connections. Also, the 96 was really OBDI tricking the system into thinking it was OBDII. You should be able to swap out the engine bay harness for a OBDI engine harness and ECU. Most of the 96's were 95's sold as 96. But that might not meet your MOT standards in Canada, because you would loose the diag port...
Posted: April 1st, 2013, 1:39 pm
by RS_OBD'oh_2
Pulling the entire harness (including dash) was not something I really wanted to do when I started out. There is something to be said about having the only turbo OBDII and fastest OBDII B6 mx-3 out there. - back to the topic at hand. If you were to use stock b6 turbo parts, it would be fairly easy to do. Mine, nothing was stock... sourcing parts took much longer than I had expected as well. Took several tries and weeks of ordering/shipping delays to finally get the correct thread type for a simple oil feed fitting. While most of the build is very straight forward, expect something to cause an issue.
Posted: April 1st, 2013, 3:38 pm
by Josh
Always give your self some time. I did my 95' in a single day initially. But I had spent a couple months collecting everything before I did it. I blew the ATX that same day...
