do you use your stock knock sensor? any issues?
i'm trying to decide whether to pull the trigger on this right now or later and this is one thing i wasnt sure about.
TO ALL MEGASQUIRT USERS.
- MrMazda92
Re: TO ALL MEGASQUIRT USERS.
I second the curiosity, I don't remember seeing anything special being required, but any information would be very appreciated!
- fowljesse
I believe I used my stock knock sensor. I'd have to check the wiring. I can't imagine that I'd have been okay with not having it hooked up!
so the more time i spend learning megasquirt and especially tunerstudio the more i like.
ve anaylize live is amazing, and i'll definetly be upgrading to a shadow dash and picking up a galaxy tab to make tuning a breeze as the temps fluctuate.
- marcdh
Never used it! When it starts making less power you're heading for knock were my tuners paraphrased words.
View Worklog
View Worklog
- WhiteFinish
marcdh wrote:Never used it! When it starts making less power you're heading for knock were my tuners paraphrased words.
- Ryan
+1 don't bother with knock sensor. Its for extreme limit OEM tune. MS is not on par with that.
You can use all of your stock sensors but you need to add an IAT for the speed density calculations.
ya i know about the external iat, i ordered the external one with my stratified order, i'm excited to swap the megasquirt in. i'm gonna leave the vaf when i first install it.....just so i can see the difference when i delete it.
