Shift issue
- kulluminati777
Shift issue
When i change gears its more harder the most cars i have driven. I have a MX-6 with a v6 as well and it is SO easy to shift compared to the MX-3. Is this normal? It takes a hard shove to get into reverse. If im still moving i can never go into first even though the RPM's are super low and im going super slow. I would have to stop completely. With the MX-6 i dont have to do that. Do i have a problem or is this normal behavior from the MX3......
Re: Shift issue
That's normal 100%, can't explain why your Mx-6 does. Reason being 1st (and reverse) are non-syncrod gears, so you can't unless you rev matched manually or double cutched maybe.kulluminati777 wrote:If im still moving i can never go into first even though the RPM's are super low and im going super slow. I would have to stop completely.
My Mx-3 was like that
My Xterra is like that
My Rx-8 is like that, but it's pretty good, it's probably a design feature because of the low torque of the motor and needing first more often than your regular piston engines.
Re: Shift issue
oh thanks nd4spd, now my comment doesn't make sense and you forced me to change it. Geez.
Re: Shift issue
My other MX-3 (the 96) shifted easily and smoothly, my 92 MX-3 is a little stiff and I don't like it either. I thought it may be those bloody bronze shifter linkage bushings. The new plastic ones in my 96 were perfect. Anyway you can try bleeding your slave cylinder and checking your pedal linkage to make sure your getting full travel when you step on the clutch pedal. My 5 cents
Re: Shift issue
SuperK wrote:oh thanks nd4spd, now my comment doesn't make sense and you forced me to change it. Geez.
Re: Shift issue
I'll back you on this one Kris. Honesty, it's not for the faint of heart.
Re: Shift issue
LOL, well I'm looking at both of your post counts and i'm thinking, "How do I get as many post counts as those two?"
"Post Rubbish."
"Post Rubbish."
Re: Shift issue
Ha, looks like you started doing that at about post #,,,,3. Gonna change your name to SuperRubbish. Ya I like that.SuperK wrote:LOL, well I'm looking at both of your post counts and i'm thinking, "How do I get as many post counts as those two?"
"Post Rubbish."
Tornado posts, home renovation posts, selling busted azz computer posts, craigslist posts, etc etc etc.
Oh and I just upped my post count by 2 .
Re: Shift issue
Daninski wrote:Blah blah blah blah
Whiner.
Re: Shift issue
SuperK wrote:Daninski wrote:Blah blah blah blah
Winner!
