rs exhaust upgrade
- wednesdayslatest
rs exhaust upgrade
so i got the 93 rs i was wondering if anyone could point me in the right direction for a complete exhaust system with 2inch pipe for my car. headers downpipe cat resinator and exhaust with all the link pipes
03 Dodge Neon (rental i had for a month but i ran that into the ground for sure)
95 Chrysler Concorde (Junked my first car [still ran])
90 Nissan Stanza (Junked [wouldnt start one day])
89 Saab 9000 CD (sedan/turbo very fun but electrical problems[city towed away for no plates on private property])
94 Toyota Camry (mothers old car fixed it then broke it[dont ask] Junked)
93 MX-3 RS (My project for 3 years so far)
97 Honda Civshit (Beater/Stereotypical POS Honda im fixing)
Re: rs exhaust upgrade
Does not exist. You will have to piece it together. Everyone here loves magnaflow stuff. High flow cat, resonator, and muffler. Welded up with some mandrel bent piping.
http://www.mandrelexhaustsystems.com/se ... Categories
That site has some good pre bent piping. The zx2 uses the same piping.
I dont think there is a header for the b6.
Took the bp+t out of the mx and swapped it into a 95 escort wagon.
- RS_OBD'oh_2
take it to a shop and get them to make it. prop be around $600 ish for the piping/res/muffler
2 inch may be a little big for the SOHC
- wednesdayslatest
well i would be doing it at the shop you see. so im just trying to get my info straight. so you say there are no headers for my car? DAMN well what would you recomend the piping for my car? what size? 1 and a half? or more someone said no more then 2inches for the mx3 but yeah i only got a SOHC.....tho if i CAN somehow get a BPT motor i will motorswap but either way i need to do up this exhaust now because its all rusty and loud :X so i would just go on the magnaflow website and order the stuff can you possibly link me to the few items i need. and as for the rest. i should just goto the autoparts store for some normal pipe? or should i get some kind of special pipe....or not special rather higher then standard/normal pipe you see at C A P or advanced autoparts
- RS_OBD'oh_2
if you are thinking about a motor swap or swap and turbo... I would wait. Coming from someone who has done 2 exhaust setups.. I'd say think ahead and do it once. If you can hold off, I would. Swap in the bp(t) and then go with 2.5 inch (talking turbo here). Better than droppin $1200 when $600 would work. I would try to get the most out of the existing setup while you can. A new muffler and res is probably a good idea... Cat may need an upgrade -where I live we don't require a Cat, so look into that if poss.
- Smashmig
corksport has a header for the b6 sohc and dohc
- wednesdayslatest
Massachusetts they require a cat too. yeah the thing is all rusted out i need to fix it i was thinkng about just cutting and replacing the stock pipe BUT its all rusted upto the cat and upto the resonator.. i deff want some new headers for sure. theyre tiny
- wednesdayslatest
http://www.corksport.com/93-97-mx3/mx3- ... ems/?sl=EN
thats the only place i seem to find them cant search google shopping or ebay for it. anyone selling any on here for cheaper? or where would i go to ask that?
you can get the downpipe from the headers to the cat cheap on ebay. Search mx-3 downpipe and you'll get some cheap options
- wednesdayslatest
oh yeah i see a nice stock cat and flex pipe and i think a downpipe but no res or exhaust. should i just conver from the cat back to a 2 inch pipe? or keep it stock i really am just trying to build up a list of parts to buy and buy them later as of right now im broke i cant fix the exhaust but it will be getting louder everyday thats for sure smh
- wednesdayslatest
headgasket is no good looks like its going to be sitting for a little while. my oil turned grey. i couldnt tell the different from the liquid and the dip stick i kept putting water in the coolant. smh oh well the headgasket should be in this week
- Josh
Pacesetter makes a cat back for the MX3, well at least they used to.
I think my pacesetter is a little too whiney/raspy sounding for my taste. I'll be glad to get rid of it. Also has a bad resonance.
Probably better off just going full custom. Road Runner here in Springfield wanted like $300 + harware (mufflers etc) for a full mandrel 3" when I was looking into it a couple years ago. Look into local exhaust places.
- Josh
The expensive part is the muffler, resonator, and cat. I would go full custom myself, I don't trust people so I build my own
