Help with the primary shaft bearing!
Posted: February 26th, 2012, 6:14 pm
so the main bearing in the transmission... does anyone know if it is different diameter between G series transmissions? I'm so transmission illiterate, and I went through the workshop manual, found the bearing, but the shop who has the transmission, says the bearings they've tried are different diameter than what's on it.
So, for example the MX-3 trans vs MX-6/probe/ect, is there a difference in bearing diameter, or are they all the same?
http://www.mx-3.com/manuals/photo.php?f ... J2-022.gif
I am fairly confident that it's the primary shaft bearing.
