Gaining access to ECU & plugs
Posted: December 2nd, 2011, 2:01 pm
by youdirtyfox
Yo Doods need a bit of help please. how do you remove the ECU from the car so you can get to the plugs with a nice long bit of lead?
Im trying to remove one from the breakers, Ive got to ECU no problem, but there seems to be like riv-nuts holding a cover in place. Have tried extension bars and sockets from the otherside, but its just not having any of it...
Im wondering is the ECU held into a plate bolted into the body somewhere as I cant see anything, not in the manual have looked and nothing came up from searching here
Re: Gaining access to ECU & plugs
Posted: December 2nd, 2011, 5:35 pm
by Ryan
Its held in with 4 10mm bolts.
Posted: December 2nd, 2011, 6:15 pm
by youdirtyfox
and you access them how?
Posted: December 3rd, 2011, 1:45 pm
by Dark_Rider2k3
i think they are on each corner of the ECU or something. I used a 10mm and i don't even think I had to use an extensionn. Just a 10mm and a ratchet.
Posted: December 3rd, 2011, 3:50 pm
by Ryan
yeah... just a ratchet? Its not comfortable to do, but kneel on the ground and stick your head under the dash, and bend your wrist funny....
I use a 2" extension on a 1/4" drive.
Posted: December 3rd, 2011, 8:20 pm
by Dark_Rider2k3
Yeah I'm mistaken. But I knew it was a 1/4 inch drive
Posted: December 11th, 2011, 5:18 am
by youdirtyfox
OK great thanks Chaps, have been out looking at mine and identified 3 of them!
left rear looks tricky to get too?! and is the right rear one also holding on the heater unit?
Front left I can find, but dont see one other yet...
Posted: December 11th, 2011, 9:49 pm
by Evo_Spec
the ECU is in the middle right at the firewall, you need to pull out the lower dash panels to gain access to it
*edit*
i just re-read everything and i'll get back to you on how to take it out, i need to go to the garage and take a pic for you
Posted: December 11th, 2011, 10:02 pm
by Evo_Spec
nevermind, i can't seem to find my spare ECU i was going to take pics of to show you the mounts.
but yeah there's 4 10mm bolts at each corner that's holding down metal brackets that are screwed into the ECU with Phillips screws
Posted: December 12th, 2011, 12:50 am
by Ryan
The one that might be confusing is the LHS one, where its held behind a nut that is also holding some plastic part on.
Posted: December 12th, 2011, 1:24 am
by RobMinhas
Evo_Spec wrote:the ECU is in the middle right at the firewall, you need to pull out the lower dash panels to gain access to it
*edit*
Crazy off topic comment but OH MY GOD YOU PUT AN MX3 EMBLEM RIGHT ABOVE YOUR PASSENGER GLOVE BOX. That's brilliant and looks awesome!
Posted: December 12th, 2011, 1:22 pm
by Evo_Spec
RobMinhas wrote:Evo_Spec wrote:the ECU is in the middle right at the firewall, you need to pull out the lower dash panels to gain access to it
*edit*
i actually got that idea off an old member here named Rekognize or something like that, he had a super nice car but he sold it.
here's his worklog if you wanna go through it
http://www.mx-3.com/phpBB3/viewtopic.ph ... =Rekognize
i found the ECU and here's a pic of it with the mounting tabs on it where you'll see where the 10mm bolts would be
Posted: December 12th, 2011, 1:50 pm
by youdirtyfox
Thats brilliant help thanks Evo_Spec, appreciate it!
