hi the problem i have with both me mx3s is that when the get up to opreating temp the idle starts to goo up and down on its own. It happen to my first one last summer and it made me park it for the remainder of it and i bought a new one just over amonth ago. and now this one is doing the same thing, on my first one i replace the tps and map sensor. has anyone had this problem as well if so could you help me out.
thanks
drew in winnipeg 92 mx3 gs v6
hey i own 2 MX3 V6 and i have the same problem with both
- _-Night-Shade-_
Re: hey i own 2 MX3 V6 and i have the same problem with both
Drew in Winnipeg everyone!!!
1) This is the Ontario Mx-3 section, you're from Winnipeg
2) If you have technial V6 questions, there's the "V6 Technical/Performance" section: viewforum.php?f=15
3) It's a common occurance, try using the Search.
search.php
4) Sounds like it's a vacuum leak and/or you're idle may need to be adjusted.
search.php
i know its an ontario mx3 section i was just try to is if anyone could help me out. and thank you
Well we do go into the other sections you know, lol.
And you can have just the Ontario guys help you, or the collective minds of the entire worldwide Mx-3 community....your call...
