help with clutch issue.
Posted: February 18th, 2011, 7:16 pm
by rajekaje
Ok so it got really cold here the other day and I had trouble getting my car to start. Once things warmed up i got right outside the next day and started it up without issue. However after this my clutch pedal will not engage. It is just very loose and will not allow me to shift. I'm not super tech savvy so I'm not sure exactly what all could be the issue here. Not sure if something might have frozen up during the bout with the cold or what. I haven't had any previous issues with my clutch and it has only been a few years since it was replaced. I haven't noticed any slipping or trouble shifting at all prior to this. Any helpful suggestions would be greatly appreciated. Thanks
Re: help with clutch issue.
Posted: March 30th, 2011, 9:28 am
by muttpower
Check for leaks first. The Flex line could have had condensation in it, and when it froze and thawed, caused it to split. When you check for leaks, have someone else press the clutch pedal in as you look, this way the hydraulic system is charged and any leaks would be more visible.
Posted: March 30th, 2011, 10:04 am
by wytbishop
If you follow the hydraulic pipe down to the slave cylinder you can actually see it extend and retract as the pedal is depressed. There are many reasons why your clutch pedal could lose firmness.
blown master cylinder seal
blown slave cylinder seal
cracked hard line
leaking flex line
broken throw out arm (unlikely but has happened)
broken throw out bearing
Check for leaks first. Make sure that the master is getting fluid from the brake reservoir. Make sure that the throw out arm is moving when the pedal is depresed. If the arm does move when the pedal is depressed, wiggle it with your hand. If it feels like it's not connected to anything that would indicate the bearing may have come apart. Worst case would be that the pressure plate springs have desintegrated. If everything else seems to be alright, you would have to separate the tranny from the engine to insepct it.
Posted: March 30th, 2011, 6:02 pm
by PATDIESEL
If the slave is moving, but the clutch still will not disengage, you could have a bent clutch fork or even a broken fork pivot bolt (I actually had the pivot bolt sheer once.... very odd). I also seen the clutch fingers get bent or not move correctly b/c of poor torquing of the pressure plate bolts.
Posted: May 17th, 2011, 4:37 pm
by garren1138
it sounds like the lines have a leak or something like said above.
when I had air in my lines it felt just the way you described.
Posted: May 18th, 2011, 12:36 am
by PATDIESEL
please don't post dredge, that was almost 2 months ago
Posted: May 24th, 2011, 11:36 pm
by muttpower
