NEED HELP KLZE Engine CEL
Posted: January 27th, 2011, 10:56 pm
by evomx
I got a KLZE in my 92 mx-3 when i jumped the connector to get the enging code it was flagging this is what i got. Im not sure what its telling me...
I got 9
and maybe 14??
Thanks
http://www.youtube.com/watch?v=fLk9mrdDCG4
Re: NEED HELP KLZE Engine CEL
Posted: January 27th, 2011, 11:05 pm
by Daninski
9 + 24
OBD-1
02- crankshaft position (ckp) sensor or circuit
03- camshaft position (cmp) sensor or circuit
04- camshaft/crankshaft position sensor or circuit
05- knock sensor
08- Mass Airflow (maf) sensor or circuit
09- coolant temperature sensor or circuit
10- Intake air temperature sensor (IAT)
11- Intake air temperature (IAT) sensor or circuit
12- Throttle Position sensor (TPS) or circuit
14- Barometric Pressure Sensor
15- Oxygen sensor or circuit
16- EGR valve position sensor or circuit
17- Oxygen sensor (check the fuel and ignition system performance)
23- Rear 02 sensor inactivation error
24- Rear 02 sensor inversion error
25- Fuel Pressure Regulator Control Solenoid or circuit
26- Solenoid valve(purge control) or circuit
28- EGR vaccum solenoid
29- EGR solenoid vent or circuit
34- Idle Air Control(IAC) valve or circuit
41- VRIS #1 solenoid
46- VRIS #2 solenoid
67- Cooling fan relay or circuit
69- ECTF sensor
111- System pass
112,113- Intake Air Temperature(IAT) sensor or circuit
116,117,118- Engine Coolant Temperature(ECT) sensor or circuit
121,122,123- Throttle Position Sensor(TPS) or circuit
157,158,159- Mass Air Flow(MAF) sensor or circuit
172,173,179,181- Heated oxygen sensor(H02S) or circuit
211,212,213- Ignition system
214,244- Camshaft position(CMP) sensor or circuit
327,332,337- EGR function sensor or circuit
411,412- Idle Air Control(IAC) valve or circuit
452- Vehicle Speed Sensor(VSS) or circuit
511,512,513- PCM
519,521- Power Steering Pressure(PSP) switch or circuit
522- Transmission range sensor or circuit
536- Brake On/Off (BOO) switch or circuit
538- Dynamic response test
539- a/c sensor or circuit
554- Pressure regulator solenoid valve or circuit
559- a/c relay or circuit
563- cooling fan relay(high speed) or circuit
564- cooling fan relay(low speed) or circuit
565- Purge control solenoid valve or circuit
571- EGR solenoid valve(vent) or circuit
572- EGR solenoid valve(vaccum) or circuit
998- PCM
Posted: January 28th, 2011, 11:19 pm
by mikeinaus
the code 9 is from the 2nd coolant sensor that probably didnt come with your klze. if you still have your k8 and look near the coolant fill cap there is a sensor your klze is missing. you need to drill/tap a hole and put that sensor in to remove the code.
Posted: January 29th, 2011, 4:00 am
by evomx
you guys are amazing!!!!
Posted: January 29th, 2011, 4:04 am
by evomx
so would that cause the rpm to jump up and down?
Posted: January 29th, 2011, 9:39 pm
by mikeinaus
it can, the ecu uses the sensor to adjust the fuel mixture.
most bouncing idle is from vacuum leaks thow.
Posted: January 29th, 2011, 11:27 pm
by mxmikey
That sensor causes the idle to bounce around a lot as well as just stop and start to bounce, my sensor went bad last summer.
Posted: February 17th, 2011, 4:15 pm
by evomx
what temp sensor works with the klze?
