found nothing special at the search
does the V6 is really compatible with the DIY Autotune ECU? Miata 4cyl ok but the same ECU for the V6?
-> http://www.diyautotune.com/catalog/diyp ... p-384.html
someone bought one of these and its running?
That IS MegasquirtRedAutobotMX3 wrote:So this has the potential of Megasquirt
Or get a 36-1 626 crank pulley (and coilpacks and bin that POS distyDaninski wrote:wytbishop does redneck. Never thought I'd live to see that.![]()
You just have to make sure you have a cam sensor in your disty. Megasquirt uses that. Our 92-93s have them, not sure on 94, 95-96 no cam sensor so. If you don't have a disty with a cam sensor you need to get one and swap it for yours being careful that the 3 wire plug wires are in the proper order at the disty. (see HEI mod in FAQ section)
