MX-3 OEM Wheel Weights
Posted: December 10th, 2010, 4:39 pm
by 93BlackMX3
I am trying to find some OEM wheels (not limited to mazda wheels) that are lightweight and I can paired with lightweight tires.
I have been looking around for specs on oem mazda wheels and all I found was lots of info on miata wheels but nothing on mx-3 wheels.
I'd like to know the size and weight of mx-3 oem wheels.
1992-1993 GS 15" Alloy Rim (Standard)
1994-1996 RS 14" Alloy Rim (Option)
1994-1996 GS 15" Alloy Rim (Standard)
1993 GS 15" Alloy Rim (Special Edition)
Re: MX-3 OEM Wheel Weights
Posted: December 10th, 2010, 6:01 pm
by Savin
94+ GS - 13lbs (lightest OEM mx-3 wheel I believe)
92-93 GS - 17lbs 2oz
That's all I could find from searching...
Posted: December 10th, 2010, 7:59 pm
by solo_ryder
94+ rims are 13.3 lbs. Wtf is a lightweight tire?
Maybe you should look at some aftermarket rims. You can get some insanely light 15" rims if you look around. Maybe you can pair them with some lightweight tires. Lol.
Posted: December 11th, 2010, 1:05 am
by 93BlackMX3
Depending on the tires, material, dimensions, or/and style, it can change how much the tire will weigh.
example:
Kumho Ecsta Supra
205/40R16 19 lbs
205/45R16 20 lbs
205/50R16 21 lbs
205/50R16 22 lbs
205/55R16 22 lbs
205/55R16 23 lbs *seems like sidewall size adds weight*
225/40R16 21
225/45R16 25
225/50R16 24
225/55R16 27 *again seems like sidewall adds weight all though not as consistent*
205/40/R16 would be what I'd consider "lighweight tires."
I was just using "Lightweight tires" as a term to explain, tires that are lighter then others lmfao
http://www.team-integra.net/forum/displ ... Position=1
http://www.350zmotoring.com/forums/modi ... tires.html
Posted: December 11th, 2010, 1:41 am
by Ryan
So basically you're pointing out that a smaller tire will weigh less. Don't forget tire compound, tread thickness, overall design, number of ply's.... pretty much every possible spec of a tire will change its weight/performance.
You could plot the data for rim sizes versus weight, and pair that to possible tire sizes, develop a modeling equation, and then calculate the derivative, find the local minimum, which indicates the lightest wheel/tire combination, and then you have successfully optimized the system!
But then your poor reaction time at the track far outweighs the detriments of having an extra rotating lb on your tires.
no to mention if you pick a hard a-- tire you won't have any traction, etc...
Basically what I'm trying to say is weight isn't your only concern! Not even your biggest.
Posted: December 11th, 2010, 2:29 am
by solo_ryder
93BlackMX3 wrote:Depending on the tires, material, dimensions, or/and style, it can change how much the tire will weigh.
example:
Kumho Ecsta Supra
205/40R16 19 lbs
205/45R16 20 lbs
205/50R16 21 lbs
205/50R16 22 lbs
205/55R16 22 lbs
225/40R16 21
225/45R16 25
225/50R16 24
Well yea, thats common knowledge, larger size = more rubber = more weight. But, who in thier right mind is gonna run 205 40 16 on a mx3? You would have wheelgap for a week and it would look ridiculous. 205 50 16 or 215 45 is the proper size. Anyways, your best off getting a super light rim (15" MAYBE 16" if you are lucky to find a set) and a NORMAL sized tire and some light lugnuts. If you have a low performance motor it really doesnt matter anyways, unless you are auto-x'ing or something
Posted: December 11th, 2010, 2:33 am
by 93BlackMX3
I agree with your statement. Although I was just asking for weight on oem wheels. lets just leave it at that lol.
Posted: December 11th, 2010, 2:36 am
by Evo_Spec
5 spoke is lightest by far (94+ GS)
