Fuel management unit / Adjustable fuel pressure regulator
Posted: October 17th, 2010, 10:13 pm
What is the difference are they two totally different setups? Like a 12:1 FMU is basically the same thing as setting the PSI of the fuel flowing through the rails on an adjustable fuel pressure regulator? Is there a chart for the different fuel pressures. or do you just tune it off of your wideband I'm confused would appreciate help guys thanks
can you run both?
can you run both?
