'94 K8 ECM bad input
Posted: August 22nd, 2010, 4:26 pm
by jmdearras
My ECM crank angle sensor got fried when the timing belt idler pulley bolt broke, and the pulley clawed it's way out, shorting the sensor harness.
I've fixed the timing belt, and replaced the sensor, but the ECM does not see it. (yes, I reset the error code). The car is running ok, on the sensor in the disty, I assume.
My question is: Can I use a 92-93 ECM, or is the 1994 ECM different, as much of the car is?
Thanks!
Jim
