also is the clutch the same for 1993 and 1994? Im looking online and found some good deal on 93' clutch.
[WTB] Clutch
[WTB] Clutch
My clutch is really starting to slip and its pissing me off
lol. Im looking for a stage 1, but if nobody as any in good shape then an oem one would be fine. For a 1994 GS K8
- _-Night-Shade-_
Re: [WTB] Clutch
They are the same for any year GS.
Sleeper6
Re: [WTB] Clutch
First as Im not sure how good you are at diagnosing but check your slave cylinder as they tend to wear out before the clutch. When mine started slipping thats all that was wrong but I swapped everything anyhow. Second use a 2.5L clutch from a probe/mx6 as they will give you more surface area and install just fine. Finally make sure you take your flywheel off and have it machined out exspecially if your going with the 2.5 clutch as you will need to have it machined all the way to the edge where it bolts to your pressure plate otherwise youll have a good centimeter or so of rough metal thats not finished from the factory and its good practice anyhow.
As for the clutch if your using the stock 1.8 the oem 2.5l clutch will hold up fine, my still hasnt slipped and I hammer the daylights out of it, but you can always look into braided steel lines from the master to the slave as well to help with any slipping. Oh and any 93-97 2.5L clutch set should work for you
Re: [WTB] Clutch
Ok cool, thanks for the info guys
