Cable speed sensor to electric swap
Posted: March 27th, 2010, 12:17 pm
So I bought a totaled car with the hopes of swapping the 1.6L DOHC from it into my 1.6L SOHC but decided not to do the engine swap. Now I read that I can use the transmission off the DOHC engine but I have run across a small problem. My 1993 MX3 has a cable speed sensor and the 1995 MX3 donor trans has an electronic speed sensor. How do I bypass or wire it for my speedo to work in my 93 MX3 ?
