QUESTION
Posted: February 25th, 2010, 12:53 pm
by boneshaker27
is there any way to clean a fuel pump ?
just asking
or replacing it is the only way
Re: QUESTION
Posted: February 25th, 2010, 1:34 pm
by KL01 FrEaK
just replace it, if the pump is failing due to mechanical/electrical resistance(too high of an amperage or voltage draw) then its dead, new pump, meet gas tank
Re: QUESTION
Posted: February 26th, 2010, 6:26 am
by boneshaker27
so the fuel pump would be a cause of the car turnin over but not starting at all right
Re: QUESTION
Posted: February 26th, 2010, 6:31 am
by Evo_Spec
could be, amongst many other things that could cause a car not to start, most people suggest to check your intake/vacuum hoses first, if your having a problem starting
Re: QUESTION
Posted: February 26th, 2010, 6:37 am
by boneshaker27
well they are all good and no leaks
Re: QUESTION
Posted: February 26th, 2010, 6:40 am
by Evo_Spec
well then the next step would be to check spark, if you get that, then yeah, it may be your fuel pump, but there are ways to check if your getting fuel or not either, trying searching on these forums about starting issues, you can use search terms like "car won't start" "troubles starting" "help with starting" or random stuff like that, there's lots of threads about it
Re: QUESTION
Posted: February 26th, 2010, 6:51 am
by boneshaker27
thanks i will keep you all posted on the results
Re: QUESTION
Posted: February 26th, 2010, 7:10 pm
by boneshaker27
well the fuel pump is a new one so i just want to know if the fuel filter would stop it as well from starting ?
Re: QUESTION
Posted: February 26th, 2010, 7:58 pm
by Nd4SpdSe
Absolutely.
Re: QUESTION
Posted: February 26th, 2010, 9:07 pm
by Ryan
We should make it a forum habit to just answer "yes" and "no" for questions that have been explained TO DEATH.
Re: QUESTION
Posted: February 27th, 2010, 7:39 am
by boneshaker27
ok thanks a million
Re: QUESTION
Posted: February 27th, 2010, 8:30 am
by Daninski
"yes" and "no"
