Page 1 of 2
Yea about this
Posted: May 26th, 2009, 9:22 pm
by headhunter1213
ok so this guy at work is wanting to sell me a 1992 mx3 v6 with around 160k miles on it.He says he only wants to sell it because he cant drive a stick period. He got it because he wanted to learn but he lost interest in it. It has the stock engine I think(didn't take a good look) passenger window smashed out but it runs and the clutch is decent.it has an oddly high idle (around 2k) but it sounds good with no loud ticks or anything like that. It has had a small crash in the front right and has the core replaced. Im kinda trying to get as much advice as i can get as soon as possible because hes sellin it for 300 and my bro sorta blew up my 1990 civic LX. she was a good car. until the radiator blew the hood open and made a 50 foot geyser.what do you guys think. Should I buy or not?
Re: Yea about this
Posted: May 26th, 2009, 9:24 pm
by solo_ryder
Pics or cannot judge. Ppl have a funny thing here on the forum for buying a 300$ car that ends up being a 300$ car after investing alot of time and money on the car.. Be careful and post up some pics
Re: Yea about this
Posted: May 26th, 2009, 10:41 pm
by hgallegos915
wow 300.. thats cheaper than a shell..I would so getthat car even if it was NOT running, as long as it has no rust.
Re: Yea about this
Posted: May 26th, 2009, 10:45 pm
by Mx3Kid16
uhhh go to and turn the little screw that makes the idle go down and there should be a spring that holds the throttle down or something like that if the idle is still up ehh and yeah if it looks like a peice dont get it dude
Re: Yea about this
Posted: May 26th, 2009, 10:54 pm
by onlytrueromeo
^That is not the proper way to set the idle.
To properly set the idle:
Warm car up. Turn car off.
Open the diagnostics box near top of engine bay and put a paper clip between the pins TEN and GND. Be careful not to jump anything else.
Turn car on.
Slowly turn the screw on the throttle body until RPMS drop to ~650.
Pull Paperclip while car is still running, and let car idle for a minute or 2.
If the screw turns all the way in and idle doesn't drop, you most likely have an air leak somewhere.
Re: Yea about this
Posted: May 26th, 2009, 10:57 pm
by Mx3Kid16
Thanks romeo ive been absorbing so much information lately im going to go try that out will it work the same for the 1.6 soch?
Re: Yea about this
by onlytrueromeo
Yup, same for all mx3's, the only difference is the location of the screw!
Re: Yea about this
Posted: May 26th, 2009, 10:59 pm
by Mx3Kid16
okay check back in like 10 minutes ill see what happened;D
Re: Yea about this
Posted: May 26th, 2009, 11:03 pm
by headhunter1213
hThe body is near flawless except for a small dent near the gas door.the floor pans, frame and everything else looks to be in order and rust free.i was planning on getting it and within a year or so put a klze in it. Theres a junkyard by my house where i can get the window for cheap. The car is that weird teal looking color.
Re: Yea about this
Posted: May 26th, 2009, 11:05 pm
by onlytrueromeo
The best way to check if she is rust free is to take a wheel or 2 off (or all 4) and check all the wheel wells, then pull up the carpet in the trunk and check the corners of the trunk (specifically the right corner nearest rear of car, under the washer reservoir if there is a rear wiper.). These are the places rust likes to hide in the mx3.
Re: Yea about this
Posted: May 26th, 2009, 11:11 pm
by Mx3Kid16
okay car is idling right now at about 650 just pulled the paperclip ran inside to type this message now im going back out to look at it what should be happening?
Re: Yea about this
Posted: May 26th, 2009, 11:15 pm
by onlytrueromeo
You let the car idle after pulling the paperclip to store the settings to the ECU. Some people say it happens right away, but I like to be on the safe side and idle the car after every ECU trip. Nothing happens, so if you're waiting for something to happen, it won't! :lol:
Re: Yea about this
Posted: May 26th, 2009, 11:22 pm
by Mx3Kid16
Nope I wasn't just a question. So i just took it around the block and it works great. Never knew that i had an idle problem lol this will probably help save some gas cause my car would go between idling at 1,500 and 1,000 NEVER lower now it goes right back to it everytime;D AWESOME
Re: Yea about this
Posted: May 27th, 2009, 1:09 pm
by headhunter1213
I might go look at it again today and maybe get a compression tester from my brother. If you do the whole thing with the paperclip will it hurt the car in any way shape or form?And about how much would it cost for a klze and mounts and everything else needed in the swap?
Re: Yea about this
Posted: May 27th, 2009, 1:39 pm
by 93vtecklr
Call a supplier in your area, sometimes a member here will sell a ze if they're upgrading or need room in their garage! Don't know where you are but google it, if you use the search function on this site you'll be able to find everything you need to stiffen up your mounts. I say buy it, but buyer beware.
