boost on stock 1.8 v6
Posted: April 30th, 2009, 10:13 pm
by asimpson719
anyone ever put a turbo kit on a 1.8 v6
im looking to do this and play around with it to see what this motor can do.
what is a safe psi to boost on stock internals?
Re: boost on stock 1.8 v6
Posted: May 19th, 2009, 7:20 pm
by muttpower
believe it or not, the stock k8de bottom end is built pretty tough...forged rods, balanced n forged crank...i do know for certain that a healthy stock k8 can easily handle 6psi. Possibly more, but dont know for certain. All set ups I've seen were built from scratch
Posted: May 19th, 2009, 7:44 pm
by Nd4SpdSe
Heh, those rods may be forged, but they're not beefy...
They'll handle OK boost, but from what people have said, not much. And your auto trans would probably blow up before the motor did.
Posted: May 19th, 2009, 11:02 pm
by muttpower
never said they're beefy, but puny forged is still better than puny cast...like i said, the best I've seen on stock internals is 6psi...i've heard of higher, but that's just hear-say...but yes, as said earlier, the auto tranny is your main setback...
Posted: May 20th, 2009, 3:34 pm
by hppwdn
One of the guys down here ran 14psi daily driven on his K8. If you think about it, K8 rods are about the same thickness as KL rods, but their shorter. That makes them a little stronger in terms of how much psi they can handle. The only problem is they have to run that much extra boost just to catch up to what the KLs make on lower boost. I think he ran a 14.4 on 10-12psi.
Posted: May 21st, 2009, 9:26 am
by asimpson719
Nd4SpdSe wrote:Heh, those rods may be forged, but they're not beefy...
def dont have a auto trans =)
Posted: May 21st, 2009, 7:28 pm
by RS_OBD'oh_2
see Se7en's work log. I think his psi was in the double digits.. I believe he had 200-250hp on his stock k8 /w turbo.
Posted: May 22nd, 2009, 10:46 pm
by asimpson719
RS_OBD'oh_2 wrote:see Se7en's work log. I think his psi was in the double digits.. I believe he had 200-250hp on his stock k8 /w turbo.
so if you can pull 250hp out of a stock k8 whats all the hype about doing a ze swap
why not just use the k8...
Posted: May 23rd, 2009, 1:04 am
by Nd4SpdSe
The reliability of a stock motor that'll last a long time
Posted: May 24th, 2009, 6:16 am
by hgallegos915
yeah but se7en's set up was good, he had msns which he knows how to assemble, he had good parts.
When my friend ivan blew his millenia ze, we installed his back up engine, his 7 psi against my 5 psi ze, my ze was way faster, spooled the same turbo faster.
a turbo k8 is still better than a n.a k8 tho ;D
Posted: May 25th, 2009, 2:34 pm
by Nd4SpdSe
Indeed, but it helps if you know what you're doing too.
But I would put money against that a turbo K8 would last a long time, and they're usually up there in miilleage too. Put in a nice, young ZE and you should get another 100-200'000kms out of it...a (non-factory stock) turbo motor will not last 200'000kms
