clutch's friction point is different everyda-----SOLVED!!11!
Posted: April 17th, 2009, 3:30 pm
ok, i need someone to explain that to me, i just cant figure that out
changed the clutch master cyl. in 2007
changed the slave cyl. in 2008
just changed the shole clutch line in 2009
when i dosen't use the clutch for a while, let's say during night, or after 1h of highway in 5th gear, the clutch pedal feel is completely gone, the pedal come's up again by itself, but dosent offer any resistance at all
so i pump the pedal a dozen of times and it comes back to PERFECT... i'm doing trafic, it'S irreprocheable, i'm doing highway and i'm loosing it completely...
i changed everything, ajusted my pedal to tha maximum, and bleeded for 1h for basically nothing
how can my clutchline assembly cant hold the pressure,
it sure can build it, why wouldn't it hold it....
i have no leaks whatsoever and everything have between 5 and 10 000km max
HELP!
HELP!
