Engine Oil
WhiteFinish
Engine Oil
Post by WhiteFinish »
I've tried to search it, but couldn't find it that easily.
So here is the question again.
What kind of Engine Oil would you use in a V6?
Is it dependable on outside temperatures?
- mile on the engine?
- maybe other things
Currently I'm using 5W30 full synt oil. But, maybe it's a bit thin for an engine with 100k on it.
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
Re: Engine Oil
there was a BIG discussion on this last year. I'm going to do a search as I want to go synt. Lots of pros and cons about each brand. Check again it must be there. I'll search later when I have time.
tehbrookzorz
Re: Engine Oil
Post by tehbrookzorz »
There's a FAQ on the forums at http://6crew.com" onclick="window.open(this.href);return false; that was derived from information at http://www.bobistheoilguy.com/" onclick="window.open(this.href);return false; . There is some very interesting information there.
Cody
WhiteFinish
Re: Engine Oil
Thats a great write-up !!
Worklog click
Re: Engine Oil
tehbrookzorz wrote:There's a FAQ on the forums at http://6crew.com" onclick="window.open(this.href);return false; that was derived from information at http://www.bobistheoilguy.com/" onclick="window.open(this.href);return false; . There is some very interesting information there.
maybe I am a n00b but I can't find the FAQ on that forum? :freak:
WhiteFinish
Re: Engine Oil
Go to the Forum and search for "motor oil" it's the 3th or 4th thread.
Worklog click
Re: Engine Oil
Post by wytbishop »
Im running Castrol 10W30 Synthetic right now. At my next oil change I'll go to 10W40. When it gets really hot in the summer I'll go to 15W40.
Mad Cow
Re: Engine Oil
Post by Mad Cow »
Wow, shows just how much I know about motor oils, turns out I know absolutely nothing.
And wytbishop, you should read through that thread http://www.6crew.com/forum/showthread.p ... ight=motor, you'll find out that it's always better to run 0Wxx oil unless you rarely change it.
KLZE-ed '94 RS/'92 GS hybrid -- It's complicated :lol: -- Now somebody's winter beater
1999 Audi A4 2.8Q -- New ride
93vtecklr
Re: Engine Oil
Post by 93vtecklr »
uhhh, you're supposed to change the oil??? :freak:
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
Re: Engine Oil
Mad Cow wrote:Wow, shows just how much I know about motor oils, turns out I know absolutely nothing.
Oh man I actually just read most of that. Burned out my last brain cell doing it. So wytbishop, Castrol 10W30 Synthetic is working well for you? I'm changing over to syn oil and I want to make an informed choice.
Ryan
Re: Engine Oil
Post by Ryan »
Oil is a huge matter, as its what usually kills a motor in the end.
It seems all the article I read said was "Buy 0W30 Synthetic"
Sweet.
Re: Engine Oil
Post by wytbishop »
Yes the engine definitely feels slipperier.
But seriously Dan, I can't imagine how you'd feel or even notice a difference between motor oils. Even if you had the completely wrong oil in your engine you wouldn't know until it started to wear out really fast. But the benefits of Synthetic oil are well documented and my ZE is in just amazing condition and I'd like to keep it that way. $45 every few months is not too big a deal.
Whenever I install a used engine I always run the first few hours with Heavy Duty oil to clean out some of the gunk. Then I switch to the appropriate weight of synthetic for the climate. Change the oil WITH A NEW FILTER every 5000km (3100mi) and your engine will be very happy.
mitmaks
Re: Engine Oil
Post by mitmaks »
wytbishop wrote:Im running Castrol 10W30 Synthetic right now. At my next oil change I'll go to 10W40. When it gets really hot in the summer I'll go to 15W40.
why would you run truck oil in mx-3? :shrug: I run same in my Cummins Diesel, that's some thick stuff.
_-Night-Shade-_
Re: Engine Oil
Post by _-Night-Shade-_ »
I just switched over to synthetic (5W-30) and it's working out great, no leaks, and I actually noticed a slight improvement in fuel economy. Dunno why, only explanation I can think of is if engine's more slippery it would take less energy to drive it? Wish I had oil temp & pressure gauges though... then I could really get the best results.
Ryan
Re: Engine Oil
Post by Ryan »
Our winters get down to -40ºF/C (same number)
so in winter I'd love to run 0W30 Synthetic
and in summer I'd love to run 10W30 O-Natur-elle
because I feel no need for synthetic in summer. I'm good with my oil changes.
