Page 1 of 2
Graphics
Posted: January 7th, 2009, 6:25 pm
by JayJ
Hello there!
Just curious,
I'm currently in an Internet Graphic Design course learning about lots and lots of things!
Just a heads up, if you're wanting a revamp or anything to do with banners, images... and what not, I could help out with things like that :D.
Just give me a shout?
Re: Graphics
Posted: January 7th, 2009, 7:20 pm
by MX-3.com
Thanks JayJ,
I appreciate the offer, but I am happy with what is on here right now. The only thing that I can think of is the little smiley faces, are designed for a white background, so on this black background, there are a lot of little white pixels that make it look "unclean".
The other thing is the "Make a Donation" image on the top right of everyppage, I notice appears in IE7 nicely with a black bacground, (transparent), but in IE6 it still shows a white background around it.
I know these are very minor things, and probably not something a Graphics Design student would be interested in working on, but you asked.
Thanks,
Jeff - MX-3.com
Re: Graphics
Posted: January 7th, 2009, 9:10 pm
by JayJ
The reason why the MX-3 icon shows up with a white BG in IE 6 is because it is a PNG and IE6 can't read it properly... Make it a GIF might help, but then you'll lose some of the Quality due to the glow on it. The only other thing I can really say to do would be this:
Making it on the proper BG... The only issue then is simply that if it moves... the BG won't look right... :S
Re: Graphics
Posted: January 7th, 2009, 9:41 pm
by MX-3.com
Yes I know, I tried all that at the time I created it. I was hoping you had some magical solution that would help! :P
Re: Graphics
Posted: January 7th, 2009, 9:47 pm
by JayJ
did you make the forum from scratch? I.E Do you have the entire code?
'cuz you could create the MX-3 in the banner and then make the MX-3 area a hot spot to click on :0 ?? :D lol
Re: Graphics
Posted: January 8th, 2009, 10:43 am
by Custommx3
The layout and the forum is phpBB (see the bottom of the page). The layout is a theme. The top graphics, I designed.
Re: Graphics
Posted: January 8th, 2009, 12:00 pm
by MX-3.com
Look at you Barry, taking all the credit! :P
Re: Graphics
Posted: January 8th, 2009, 5:09 pm
by JayJ
kk they give you any leeway with the HTML / CSS? stuffz?
Re: Graphics
Posted: January 8th, 2009, 5:25 pm
by Mnemonic
up top he has lead way with the beautiful graphics that BERRY did... :)
But I believe and Jeff/Barry you can correct me if I'm wrong the rest is php.
JayJ do you have a website for me to check out? Only reason I ask is because I'm a Digital Media/Graphic Designer. I do web/print/video.
Re: Graphics
Posted: January 8th, 2009, 6:21 pm
by JayJ
up and running real quick to get some information out.
I have one for my bro that I put together within a couple of hours...
but other than that, nothing on the internet... I've got a few on my PC that I've worked with.
also, learning ASP and CF at the moment... PHP Shouldn't be that far off :D
Re: Graphics
Posted: January 8th, 2009, 8:02 pm
by MX-3.com
All jokes aside, I am seriously not interested in redesigning the forums. I am ok with the phpBB forums the way they are.
The main website at http://www.MX-3.com" onclick="window.open(this.href);return false;, could possibly use a revamp, but I personally do not have the time. Ideally I would like to put it on a CMS template type system (Content Management System), where the body and form of the site is there, and I can simply, edit the body of the page to modify the content.
The site used to run on Cold Fusion Markup Language (CFML), but that was a number of years ago, and I have since changed my web host that does not provide CFML support.
I am ok with that, as moving forward, I would prefer to have the site running off of PHP and mySQL. Currently I have al the pages running on php code, but the database connections are not working, as I don't have the time to learn the code and make the appropriate changes.
Re: Graphics
Posted: January 8th, 2009, 9:31 pm
by onlytrueromeo
Main webpage needs a revamp anyway as 1/2 the links dont work!
Re: Graphics
Posted: January 9th, 2009, 12:45 am
by Mnemonic
Jeff I'll hit you up tomorrow and we can talk.
Re: Graphics
Posted: January 9th, 2009, 9:43 am
by MX-3.com
After your comments above, what if I don;t want to talk to you! :P
:laugh:
Re: Graphics
Posted: January 9th, 2009, 10:13 am
by Mnemonic
lol nothing was negative for you :)
