First obstacle - AWD! I would do the AWD swap and strengthen the chassis at the same time.
The tricky part about this is that I want to use a KLZE to power the beast...I am still trying to figure out if this is possible and what I would have to do to make it work.
Car will be able to attain at least 180MPH. I will accomplish this by either changing the gear ratios dramatically or by swapping to a different 6 speed AWD tranny, and custom fitting it. I would have to make custom adapter plates and mounts, etc, but I am confident anything is possible!
-Straight cut gears! Cryo treating and micro polish!
Full adjustable suspension controlled from inside the car.
 If thats not possible, then some sort of coilover system will be used thats not too harsh for a daily driver.
 If thats not possible, then some sort of coilover system will be used thats not too harsh for a daily driver.Poly bushings everywhere!
Car-computer connected to ECU so that I can monitor all engine stuff and log it!
T-Top mx3 conversion if I could make it look really good.
Projector headlights.
Either Eurospec front bumper or MSP front bumper with fog lights, RSX rear lip on the back and some good looking sides that match the car. Red painted tails, either stock or altezzas but I would modify them so they did not get water in them.
Either a custom spoiler so its not more than 2-3" above the hatch, or mold the Eclipse spoiler.
CF Hood w/ vents like Yence's but with the angry eye mod, and painted to match the car.
Custom made fuel tank to fit under the car even with AWD setup.
Suede headliner and door inserts. Racing seats w/ 4 point harness. Chrome miata handles, 5.1 Surround stereo, touch display where deck normally is. Audi TT vent mod on 94+ dash, and flocked dash to prevent awful sunglare.
Tint on all windows, with Jesse's slim visors on the doors.
Heated, power folding mirrors.
Full soundproofing in car, rear seats removed and back built flat to use as an oversized trunk (with amps underneath the built up floor).
Remote mount turbo because the engine bay is cramped on a v6. If a ZE can't be used, I'll just do a normal turbo setup w/ a 4Banger. 300 AWHP, daily driven on pump gas.
Full standalone, with different fuel maps for gas mileage or racing/fast driving. Launch control, two-step, the works.
Relocated battery.
Full engine bay wire tuck.
Spray the entire interior/exterior/frame so its in nice perfect condition.
I want to have water/meth injection built into the car so I can run lean. I want a digital controller hooked up so I can monitor the system inside the car and want at l east a 3 gallon tank that looks like it belongs where it is.
I want to upgrade the A/C and heater systems to perform better than stock so the car will be the best Daily Driver ever.
Custom gauges so that the colors can be changed and needles light up.
A pillar 3 gauge pod w/ Boost, Wideband, Oil Pressure.
Lightweight 15-16" Rims w/ best tires for the season. Really wide for summer, nice and skinny for winter.
Full Rustproofing and underbody spray, fill in where mazda engineers left off - fix the door jam problem, and fill in the empty space in the metal under the doorsills.
Rebuilt motor from ground up, bored as much as feasible - resleeve if necessary.
10:1 CR pistons and forged rods, titanium valve train. I want to rev up to 9k safely.
COP's used from whatever Honda motorcycle fits the ZE.
External Oil pump and relocated Oil filter, w/ Oil Cooler. S/S Reusable oil filter.
Powder coated engine pieces and suspension pieces - most of them black, but engine bay will look nice w/ some blues or silver.
Car color: Thinking Daytona Blue from a 350Z
http://img158.imageshack.us/img158/1635/side99ul.jpg" onclick="window.open(this.href);return false;
I think w/ everything I can keep the car under 3000 pounds w/o me in it and with all the suspension upgrades and power I will be making it won't feel that much heavier than stock.
Any suggestions? Comments? LOL If I ever get the chance to do this it's going to be at least 3 years before I start it. Cost estimate: $18000-25,000, depending on how much of the skilled stuff I do myself, and probably not counting the adjustable suspension stuff. For an electronically controlled suspension, I'd imagine at least $10,000 more!
