Pic request : 94 style DISTY plug wires
Posted: October 24th, 2008, 3:06 pm
by solo_ryder
Hey,
I need this asap.. I need a picture of the wiring order on the 3 pin plug on a 94 disty. Should be a Blue/Red/Yellow.blk wire. I am not sure of what order though as I have changed them around.
Thanks
Re: Pic request : 94 style DISTY plug wires
Posted: October 24th, 2008, 7:02 pm
by solo_ryder
noone wants to take a pic for me real quick of the plug and the wires? I need this to get my car running..
Posted: October 25th, 2008, 2:54 pm
by solo_ryder
Comon guys I really need this
Posted: October 25th, 2008, 5:21 pm
by Savin
Will the wire order off the '94 B6 disty be ok? I assume its the same?
I can't take a pic, but I can at least give the order....
*gets back from checking car*
Blue is closest to the front (closest to you/the one on top)
Red is middle
Yellow is furthest away. (bottom)
Posted: October 25th, 2008, 5:36 pm
by solo_ryder
THANK YOU.
So the blue is closest to the firewall and the yellow is closest to the rad correct?
Posted: October 25th, 2008, 5:52 pm
by Daninski
Ok here's a link, spent my valuable time finding it. Cost, 2 beers. http://www.clubprotege.com/wil/howto/hei/index.htm" onclick="window.open(this.href);return false; Hope it helps, theres a pic of the plug here, simply scrol down. Remeber if it helps you, 2 Beers. :)
Posted: October 25th, 2008, 5:53 pm
by Savin
EDIT:...ok...so its different than the B6....
on the B6 disty, the orientation of the plug is mostly vertical, I don't know exactly how it is with the K-series, but i'll try to accurately describe it.
For orientation purposes, you know where there's that little tab that you can push down/in ?(whatever you want to call that) Lets say that little tab thingy is up.
A pic is better than a crappy MS paint, but its the best I can do...
So I guess it would be BLUE is closest to the rad pending that the plug location on the V6 disty is the same as the B6...
Posted: October 25th, 2008, 6:16 pm
by solo_ryder
Daninski wrote:Ok here's a link, spent my valuable time finding it. Cost, 2 beers. http://www.clubprotege.com/wil/howto/hei/index.htm" onclick="window.open(this.href);return false; Hope it helps, theres a pic of the plug here, simply scrol down. Remeber if it helps you, 2 Beers. :)
Thanks, that is for the 92-93 harness though.
94 has a different setup. Thanks though!
Posted: October 25th, 2008, 6:18 pm
by solo_ryder
Savin wrote:EDIT:...ok...so its different than the B6....
Yea, the k8 disty on the 94 is vertical as well. But I think that hte b6 has a different setup.. The tach wire is near the rad *Im pretty sure*
by Daninski
Yes, I heard 94s weird.
Posted: October 25th, 2008, 6:23 pm
by Daninski
OK, my 95 is Blue Red Yellow, for what it's worth. Cheers
Posted: October 25th, 2008, 6:25 pm
by solo_ryder
Blue closest to the firewall I assume?
Posted: October 25th, 2008, 6:30 pm
by Daninski
Facing the disty cap from the drivers side fender it's Blue Red Yellow going clockwise. OR, Blue on top, red, then old yeller.
Posted: October 25th, 2008, 6:34 pm
by solo_ryder
95 only has the one plug does it not? And I think the b6 arrangement is different...
Anyways, I found the original plug here for the 94 disty.. Here she is:
Posted: October 28th, 2008, 12:17 pm
by Daninski
That's it, blue red yellow with blue being the most forward.
